Full hardtop question
fisherman
Whew, was that you?
brunswick
md
i got a full hardtop a few years back just to have on hand IF i ever get my project done. i moved the body out of the shed and thought i would put the top on it just to keep it covered while it was outside. When i put the top on, the front of the top (the part that sits right behind the door opening) is not stiff enough to stay on the edge of body without the clamps. It just spreads out and slips off the edge. Is this normal or is the top just old and worn out? i hope i explained the problem well enough, thanks for any help you guys can give me.
Normal, at least for me. Mine does the same thing
Truck
Sometimes as the fiberglass gets old it will spring out of shape.
I would suggest jut drilling a bolt hole through the flange above the B-pillar lip. The CJ-7 has a place there that is for their hard top to bolt down there. It works for the CJ-8 also if the Hard top is built that way. When you put the top on, just spring it back a little and drop the bolt through both holes and it will hold it in place.
My Full top has angle brackets bolted in place is place of the full fiberglass flange. So it is hard to keep mine on the Jeep. Had to run 1" tie downs over the top to the frame to keep it on during the Hurricane. I may go back and add that flange at some point. Not exactly sure of the make of mine. I know it is not Acme as it does not have the name embossed in it. But it does use a factory style CJ-7 rear hatch.
Carl
