- Manassas
- Va
Ok, I've been getting ready for Nationals slowly but had to ramp it up a few weekends ago. Had the Freightliner gone over by a shop since this will be the first trip that far. We are headed on to CO after Nationals since we are over half way there. Plan was to haul as many vehicles as I could. So started working on Kaufman Mini 5 that I had bought specifically for this function. The more I got into it the more I realized how poorly it had been treated. I bought 8 new tires for it and pulled the wheels off to change them out and found missing calipers, missing brake pads, spun bearings and missing and bad brake lines that I wasn't expecting. I knew it needed to some wiring love as not all the lights worked. Probably ground issues but time consuming to track down. I also needed to replace batteries and figure out why the wince won't run. So after a couple of weekends of work I realized we just weren't going to get it done. So move to plan B. Aluminum wedge trailer. So I will only be bringing 3 vehicles vs 5. It also needed work but a whole lot less. Swapped trailers from yard to drive last weekend and started working on the wedge. It needed all new tie downs as several were broken and many were badly rusted. I had already purchased them so we knocked that out. Needed to check wiring and lights, replace hinges on doors, check brakes and pack bearings. Got the tie downs done. Pulled wheels today to pack bearings all good except front axle had bad brake shoes. Second and third axles had the whole backing plates and brakes replaced with a 2022 date and looked pretty good and I got those bearings repacked and put back together. So instead of shoes I ordered a set of brakes premounted on backing plates that should be here tomorrow. I have the hinges on hand to replace. I need to mount a new battery for winch and work on electrical. Got oil and fuel filters for the truck. I need to change oil tomorrow. That will be a first. It holds 6 gallons. Still need to wash the trail scrambler. I might actually make it but I will be pushing it.
Just thought I would share... as I'm sure others having last minute issues.
Truck
Truck
