Gettin ready for Nationals
Truck
Manassas
Va
Ok, I've been getting ready for Nationals slowly but had to ramp it up a few weekends ago. Had the Freightliner gone over by a shop since this will be the first trip that far. We are headed on to CO after Nationals since we are over half way there. Plan was to haul as many vehicles as I could. So started working on Kaufman Mini 5 that I had bought specifically for this function. The more I got into it the more I realized how poorly it had been treated. I bought 8 new tires for it and pulled the wheels off to change them out and found missing calipers, missing brake pads, spun bearings and missing and bad brake lines that I wasn't expecting. I knew it needed to some wiring love as not all the lights worked. Probably ground issues but time consuming to track down. I also needed to replace batteries and figure out why the wince won't run. So after a couple of weekends of work I realized we just weren't going to get it done. So move to plan B. Aluminum wedge trailer. So I will only be bringing 3 vehicles vs 5. It also needed work but a whole lot less. Swapped trailers from yard to drive last weekend and started working on the wedge. It needed all new tie downs as several were broken and many were badly rusted. I had already purchased them so we knocked that out. Needed to check wiring and lights, replace hinges on doors, check brakes and pack bearings. Got the tie downs done. Pulled wheels today to pack bearings all good except front axle had bad brake shoes. Second and third axles had the whole backing plates and brakes replaced with a 2022 date and looked pretty good and I got those bearings repacked and put back together. So instead of shoes I ordered a set of brakes premounted on backing plates that should be here tomorrow. I have the hinges on hand to replace. I need to mount a new battery for winch and work on electrical. Got oil and fuel filters for the truck. I need to change oil tomorrow. That will be a first. It holds 6 gallons. Still need to wash the trail scrambler. I might actually make it but I will be pushing it.
Just thought I would share... as I'm sure others having last minute issues.
Truck
Ok, in traditional Truck fashion I may either not be there or there without a running jeep. I about got everything else done and no the jeep won't run. I have been fighting a fuel issue for years and I dropped the tank last year and put a new pump in it. It seemed fine. But now it is hard to start unless I'm using starter fluid. Runs for a bit and then quits. I'm at the end of my rope and about ready to shot this thing and give up. Already missing more work than I can afford...
I know that feeling. I was wanting to bring dad's daily driver Scrambler, as it has been to many Nationals.
I worked and worked on it, no telling how many hours.
I finally gave up (for now) and put it away and concentrated on getting another one going.
I’ve been fighting a similar issue about 3 weeks before going to Moab back in April. Had been running pretty well except once in a while just stalling. Then just dying and not starting. It was driving me a little wild also. Some crazy things intermittent. Luckily I went with a great guy who was pretty good diagnosing things, but still I had problems on my trip out, there, and finally just dead heading south out of Moab for a week. Rented a truck and trailer to get my baby home. Coil and adding additional grounds to the pump has me in a lot better place now, but still not 100% feeling that lovely feeling yet. My spare pump just arrived just in case. At one point we thought the pump was toast. The 2 guys decided with nothing to loose because the pump wasn’t working at all to reverse polarity on the pump. Worked. Wasn’t until I added another ground that it’s been working with no problems now for 3 weeks. The final straw that broke the camels back was the coil failing at 12am out in the middle of no where.
Got the jeep running yesterday. Rewired the fuel pump. That in and of itself was a chore as I drove all around town trying to find 12ga wire with no luck so I put my Mcguiver hat on and bought a 12ga 50ft extension cord, cut and used it. Now i have built in extra wire. However, this gave no results, so I dropped the fuel tank and found the fuel pump had become disconnected from the fuel line. I had replaced the fuel pump last year and apparently the fuel hose that came with it was to thick and cheap clamps provided couldn't lock it down tight enough. Fixed it put it back together and then went back to rewiring the trailer. Finished that last night. Now to pack, load the truck and trailer today. We are about 2 days behind but will try and get on road today.
Just to close this out...we made it to Nationals about 12hrs behind and just had to rest the first day. Wheeled day 2 and 3. Had a blast with everyone as usual. We then went on to CO and dropped jeeps off there. Fixed 3 busted pipes from winter freezing, fabricated a mount for our starlink that got blown off the roof (fortunately dish had only minor damage) and did some work on our 'farm' truck (new rear spring shackle, new fuel sending unit and locking ring and exhaust header gasket. Then back home to VA without further incident....I'll add some pix tonight. Thanks to all that encouraged and advised on issues and kept me motivated. Even with everything it was a great trip. And beats having my truck burn up on the highway like last time!!
Truck
