got a set of these today..!! for all of 25.00..!!!!
Great price. People seem to be asking high prices for door panels for CJs and now apparently YJs. They are asking almost enough to buy a pair of complete doors. I recently bought a reproduction pair of YJ panels, just the lowers, on ebay brand new for $50 shipped. Same design as the ones pictured in the ad. I wish they would set up for the CJ panels and stamp them out this cheap, too. I just did a little repair on a CJ door panel. Bottom corner was broken and some holes for the clips were sloppy. I made a new corner out of waterproof panel board and used a scrim cloth on both sides to attach it to the original panel. The scrim cloth is simply a piece of muslin or light canvas. Brush carpenters glue on the panel where the cloth will go, and on the cloth, put them together and then brush more glue on the outside of the muslin. Nest day when it is dry, flip it over and do the other side. Around the ripped holes, I use the light canvas, punch the correct size hole in it, and then glue it as before matching up the holes. If your panel is warped, spray the back side with water, put it on a flat surface, and put weights on it to flatten it out as it dries. No half way decent door panel should go to waste. Glad you are going to tune up the ones you bought.
when I said "can use some new cardboard"... I meant "completely hosed".. LOOOL
the passenger side has termite tunnels aaaalll over, in and out of it.. and both sides are quite warped..
