Half hard top glass install
gr8dain
Old and Slow
Ashburn
VA
Ok, I had a hard time trying to put the glass back in my hard half top about a year ago. It is time to put the top back on for the winter and I would like t have the glass in it this time. Any tricks to make it easier? I assume it requires the rope method. And I assume I should soak the seal in warm water to make it pliable. Soap? Anything else to make it go smoothly?
And do I need a glue of some type to seal the gasket to the hard top? I don’t know if I want to put glue in the channel until I know I can get the window in completely.
Post #2367, that's how I did it. Kind of PIA.
wow. As a realist, I am not sure I have the patience for that 🤣 I can see myself getting frustrated and just buying a used half top with the glass already in. Well, I hope not. But we will see. Thanks. And especially thanks on the tips and the confirmation of which side of the seal was for the exterior.
What a pain in the arse. Spent some time the other night putting the adhesive in the seal and putting the seal around the glass. Let it sit a couple of days. Spent about 4 hours manhandling the glass and seal into the opening of the top. The seal got messed up a bit but I am not worried. It is a wheeling rig. I just hope I never have to do that again.
Thanks for the write up your pointed me to @spankrjs it helped a lot.
