Half Hard top Glass Question
GarScramb
Parkersburg
WV
I have finally decided to sell my half hard top and started to put the back window in (that a very tall friend popped out with the passenger seat).
Well, as with most things I have tried to do with the Jeep, this turned out to be a much harder job than I had anticipated. Anyone have any tips or secrets to getting the glass and rubber seal back in place?
Thanks in advance. -Gary
What I did and I don't know if this is the proper way or not? I took the gasket and got it in place. Then I took the window and lined it up. If you pull or push from the other side of the gasket so it will meet the window edge. slowly work the gasket all the way around the window. The last section gets a little tough, but just take your time. It should pop right back into place. You may want to use a putty knife or something like that for the last corner to lever it into place?
It is just a slight pain to do. Good Luck!
TK
You may also want to pick up a set of nylon bicycle tire levers (~$4-5 at a local bike shop) instead of using a metal tool...less chance of breakage, I would guess. They usually come in a set of 2-3 so you can work it around from both directions at the same time.
Craig
This should work very much like the way that they put in a windshield... this will be a lot harder to explain than it is to do.
-Set the gasket around the opening (this assumes it will stay in place on it's own)
-get something like 1/4" nylon rope (anything that's strong and fairly smooth should work) that's long enough to go inside the groove in the gasket for the window with enough left over to be able to pull on.
-set the rope in the groove such that the rope comes out of the groove at center of the bottom of the opening (just run it til the rope meets up and then lay the extra out on the side you'll be working from).
-angle the top of the glass toward you and sit the bottom edge of the window in the groove on top of the rope, you should be able to get it to sit down on it pretty well. (make sure the ends of the rope are still sticking out on your side!).
-holding the top of the glass with one hand and pushing it back against the gasket, start pulling the rope out from the groove, this should bend the gasket out toward you as you go and if you have the glass against the gasket it should flip out in front of the glass, putting it into the groove.
-continue all the way around the glass in this fashion and you should end up with the glass seated in the groove.
The only thing I will say is that I can't recall if the guy pulled both ends of the rope at once or not, but he did it all by himself, so I'm thinking he didn't and supported the glass at the top like I mentioned.
Obviously the guy had done it before, but it was slick as snot and he was done with the whole operation in a matter of about 10 minutes (on my windshield).
Hope that helps.
small addition
yep, everything what everyone else said.. AND...
you can take a little mild dish soap and put on the window seal to help it slide into place a little bit better. This helps also when pulling the rope around the seal.
Matt
It takes time
Eric has offered good advice. I had to put mine back in once and it wasn't easy. You just have to take your time and work it in.
Dodd
Thanks a ton for all the great info guys. I'll give it another shot this weekend using Eric's method.
Craig, I'm a biker too so I have those tools. Didn't occur to me to use them for this though. Thanks!
-Gary
It's dang sure not "my" method, I was just the first to post it :D
Good luck, I hope it works for you.
You know I just thought of something. Don't stop the presses I know it happens once in a while....
Instead of a rope try and piece of flat nylon strap. Then it would fit better.
Things to remember.......
