Heater.
Wayne
Cape Coral
FL
Hello, I’m not sure if this is the place to ask this question?
Would the heater on an 82 scrambler with an in-line six be the same as a CJ7?
I’m looking at videos to see about replacing mine. I can’t see any videos with an 8 and an in-line six but there seems to be a few CJ7 vids online.
Thanks.
Thanks.
Not sure what you mean by heater...
Basically most everything is the same across the CJ's for corresponding years except for body specific parts, (tops, bulkhead, body panels behind the cab area) as well as rear drive shafts and frames due to the additional wheel base.
Here's an example:
Thank you :
That’s good to know. I will study a few videos on YouTube. I want to get ready for the 3-4 days of winter we might have in South FL.
Thank you :
Not sure if you know this but the Blazer blower motor upgrade is/was the best bang for your buck to increase the heating in the CJ's
True, it's makes an amazing difference in heat output especially in a CJ8 with a half can.
Everything from the front seats forward is the same on a CJ-7 and CJ-8. Even the wiring harness is the same to the back, it just takes a slightly different route to compensate for the longer body length.
It is when you get into earlier year CJ-5s that part interchangeably becomes questionable.
