Help wanted: Beefcake springs but no lift
jmarkel
Scrambled for Life
Fairfax Station
VA
I have been looking for options for my jeep for heavier rear springs and haven't come up with anything. Basically, I want to increase the overall payload of my jeep so that I can carry my corn, pellets, and other heavy stuff while also toting a full hardtop.
Maybe some helper springs? I'm wondering if you can get stock height 6-7 spring leafs. My dad's old chevy stepside had 7 springs and no matter how much he loaded that thing it didn't sag much.
Air Bags from someone like Firestone.
Or for a less expensive version. You could get those Air Shocks like the old hot rods had. Then you can use them on ocassion.
Not as much capacity as the truck type air bags for trailering and all. But in your situation they would be cheep and effective for loads that you would put in a Scrambler bed.
Carl
Just put an add-a-leaf in your existing springs, cheap solution....stiff ride.
Don't even know if they sell air shocks anymore, but I had 'em on a Ranchero and they worked good. The bed on a Scrambler is sort of self-limiting, size-wise/load-wise, don'tcha think? Ok, OK, you could seal it up with fiberglass and fill it with water and stress things a bit, but these Jeeps are not that big.
Paul
I thought that I saw Hijackers at the Pep Boys the other day that I went there.
They have those flyers in the Sunday paper, and the stuff looks reasonable. But once you actually see it in person. I just could not bring my self to buy that stuff.
But something like the Hijackers have been arround for a while. So they are a know quantity.
Carl
weight limits
Well, I was reading about payloads here a while back and I think we've come up with 500-700 lbs payload for a scrambler. The other day I loaded Big Brown up with 1250lbs of pellets and drove it 40 miles. No real issues other than the sag. Once I put a full hard top back on it I don't want to reduce my payload by 200lbs to accomodate it.
Overall, I don't care if the ride gets a bit stiffer...I personally like a stiffer ride.
I have recently found a 6-leaf spring set for the rear from Aida-Onyx? I bet that would be just what I'm looking for.
I don't really want to go through the trouble to bag and compressor it either. Add a leaf may be a good solution too, but for $80 a spring, I can't go wrong just replacing them. I can even live with a 1/2-1" lift I guess.
Thanks for the ideas.
Increased spring capacity
I get a little sag as well when I go off-roading due to all the stuff I carry and most of my load sits well behind the axle. I did some searching and Easton and Alcan make custom set ups but they will cost a few bucks. 4 wheel parts carries Hellwig spring helpers and they seem to be set up for what you are looking for and are affordable. They have spring helpers based on the weight you want to increase; 550, 1000, 1200, 1500, etc. The 550 looks like it attaches to the top of the springs with U-bolts and sits behind the axle up to the rear shackle. The 4 wheel parts web site does not show a good picture of it but I did a Hellwig search in google and you can get some better views of what it would look like. I would suggest calling them to find out exactly what it does but it seems to help out with a sag problem.
Karl
Do they provide lift?
Truck said:
JC Whitney has a 7leaf spring for $84, a couple of folks on here run these on all 4 corners]
Truck, do these provide any sort of lift as well? I'm trying to keep away from a lift of over 1/2" if I can.
I haven't used the J.C. Whitneys myself. From what I've seen/heard, They start off with about 1" of lift over stock. They are intended as a stock replacement. I don't recall who makes them, but it's a decent spring from a good maker.
Why don't you just get a trailer if all you're doing is hauling pellets and heavy stuff. Why service-cycle a decent Scrambler by seeing how much you can put in it?
Paul
no room
Paul
I'd LOVE a trailer! Unfortunately, I live in Arlington VA which means that there is no room for such luxuries. I have motorcycles and dirtbikes that get crammed in the back of my scrambler as well because I don't have a trailer.
Someday, I'll move out of here and back to a nice farm, but right now, I'm stuck in the City.
Gotcha,
Should've looked at your location and I would have known. I'm sure there's many benefits to living there. Tough for a Jeeper, though. You're burning pellets in the city??
Paul
pellets in the city...absolutely!
There are not ordinances other than similiar ordinances for wood burning to own and operate a pellet stove here. Unfortunately, pellets and corn are not available right down the street, so you have to load up and drive them home.
Right now, I can get a bag of pellets for $4.40 about 40 miles from here. Corn is a bit cheaper and you get 50# instead. Once the harvest is complete, corn prices will drop.
I went with a dual fuel corn/pellet insert because last year my natural gas heat was $400/month keeping the house at a cool 62 during day and sleeping hours and 68 during awaking hours.
Pellets/corn keeps the house at about 75 so far (its been in the 30's at night) and I only need to run the gas boiler 3 hours/day to heat the bedrooms and basement.
Other than the initial layout of $2500 for the stove, I figure my heating costs will be reduced at least 200 per month and it will actually be warm in my house.
Sounds like a good investment. You'll have it paid for in probably around 3-4 years. Then it's money in your pocket. Good Move!
Paul
I've had Tuff Country HD springs w/o flex it was like riding in an old freight wagon,changed to Superlift superide not much improvement, I won't go with spring over or reverse shackles don't need more problems,so my next set of springs will be from holbrook specialties after contacting owners with cj8's who installed them and are pleased with their ride and articulation http://www.holbrookspecialties.com
Thanks...
I appreciate all the leads. Not sure what I want to do yet, but I know that Ole Brown doesn't like it when I put 1200 lbs of corn/pellets in the back. The engine doesn't care, but my suspension complains.
Geographical ignorance....
I was reading this post and wondering what the hell you are feeding with all that corn/pellets....I was assuming you were talking about protein pellets and corn like we feed deer down here....I wasn't even aware you could burn corn to stay warm....Who'da thunk it....Of course this is the same site where I was introduced to a house made out of straw that someone (I can't remember who) had made up in North Dakota or somewhere...
You could get a small utility trailer that could fold up and stand up against a wall in the garage. They aren't the stoutest things in the world, but would easily be good for a 1000#'s or so....
Corn heater......Willie Nelson would be proud of you.....;)
