hey, Whatz that bracket for?
Got anything on the other side? Maybe a hi-lift? No clue.
Looks like someone made a custom Hi-Lift bracket and the lower one is gone.
It is bolted in place of where the factory tire carrier would mount. Those bolt holes were designed for the Standard CJ style tire carrier that goes across the tailgate area.
Maybe an overhead rack? is there something matching on the other side???
Carl
It is to hold the stove next to my Corian counter top.
These are some of the projects for the Scrambler to make camping more confortable for my 3 week solo camping trip to Baja. I'm planning to leave toward the end of the month and come back mid-November. If all goes as planned, I'll be set up to camp confortably even if I get heavly rained on.
Nice idea, but are you concerned about gas tank fumes from the filler cap hitting that burner?
Yesterday I built a duck board from birch and walnut slats and today I made the slide channels to receive it on my swing out carrier. The rubber bumpers stop for the swing out carrier locks it into home position.
The inside of the tail gate might need some cushions to match the kitchen set up, then it would be uber comfy, and perhaps a 110v outlet for a coffee pot.
What's going on with the brake lights?
Con Permiso...
but I'm going to turn this thread into my pre-Baja prep thread.
Originally i was planning to spend only 3 weeks down at my ranch, now it looks like I'll be able to spend more than a month due to a couple of clients "need" for imediate satisfaction. LOL
Here is my rear speaker mod (as I described on ExPo)..
I just got through with this fun modification of a pair of cheap bookshelf speakers. I made aluminum spacers that indexed into the mounting holes then fitted them with long cap screws then made plates that I riveted guide pins and rare earth magnets to back of. The net result is a speaker that has storage for about 30 feet wire and travels "stuck" to the roll cage right behind the cab... But can be un-stuck and used anywhere within the range of the cable. Like stuck to the hood, or the rear tire carrier.
And my Pre-filter additon...
In prep for my 3 week solo Baja trip (might end up being more like a month)...
i added a Stanadyne 30 micron pre-filter with a built in priming pump (for those inopportune filter changes) with a glass bowl H2O separator.
Though, Mexican diesel is ROCKEN GOOD (20% more "love juice" per squirt)... You have to be careful not fill up at non truck stations (like El Rosirio de Arriba!!!!!) because of the bottom 25% of the tank.
