Hi - I'm the new guy
Maybe this will wet your appeitite- :D
forum
That's awesome!! "Hey you guys on the sides, yeah, you, can you sqeeze into the center a little more please!?" :D
Yep, NICE Pics of National Scramble! 42 Rigs eh?
Okay THAT's IT! I'm coming to Hot Springs this year SOMEHOW. I may be "Rigless!" :eek: :D Sure would be nice to get a dozen or so of my fellow California CJ-8s to convoy with me though!!! Hmmmmmmm?????....let me think......Zero, any ideas????
think we had right at 47 or 48,there where a few that didn't make the pic-JC ;)
Aaron, It is about time you made it in here! We need more Colorado Scramblers on this board! These guys will blow you away with all the help you can get. This is a really great group of Jeep lovers from all walks of life. Start asking questions on that 4.0L swap your trying to hammer out. Where did you end up with it?? Did you get your trany/ transfer figured out?
Glad you made it!
TK
Welcome aboard!
A 4.0 conversion eh? I'm looking at doing the same thing. Keep us informed.
DC
Welcome!!
Hot Springs IS the tourist capital if Arkansas (such as it is). Not far from Little Rock.
There were several families last year. My wife and daughter were mad that they weren't invited. We are all going to try to make it next year. My son owns the 8. I rode shotgun. Drove his 8 and my XJ 700 miles to get there, and we were nowhere close to the longest drive.
Maybe you can talk them into riding one day and doing something else touristy the other?
PICS PICS PICS!
Oh, you already did that :D Once again, late getting to a thread and yet my photo-asking reputation preceeded me... I love it!!
Nice looking rig you got there... to start with :cool: 4" of lift, some 35s.... yeehaa! Let the good times roll!
I'll be starting on my own 4.0 conversion here before long if all goes well... hope that yours is coming along.
Welcome to the boards.
Sounds like Rock Springs might be doable . . . I planted the seed last night - somehow forgot to mention it had to do with Jeeps (as she steps in . . .I'd be safer with porn . . .), anyhow, she seemed open to doing some "road trips" with the family :) although I had to "steer" her South, but things are possibly going to work. And all those folks to the West of me, maybe we can caravan? So, the reason for the "stealth" when mentioning Jeep/CJ/8/Scrambler/forum(s)/tires/tranny/tops . . . Is that my wife has begun to loath the Jeep :( and the reason?? Dreams of fuel injection, and a tranny that doesn't need to get rebuilt every year - and is still short a gear . . .
That's right the 4.0 swap! :D So, I can firmly say that I am chalk-full of advice for those that are thinking of doing this - hit me up anytime. I'll give you all a brief(hopefully) rundown of the situation:
The 258 was in bad shape and I was sick of dealing with the BBD, not to mention the T-5, so after 6 weeks of drama, I finally decided that I would just do the conversion to the 4.0, and stroke it when the time came for a rebuild. Also, the Scrambler is my Daily Driver, which is where part of the wife unhappy-ness comes from.
I am not a mechanic, but I learn quick and really wanted to build my Jeep myself. I did quite a bit of research prior to getting started, which as it turns out, wasn't enough, and continue to research today . . . :)
Stage 1: Everything came out of the Jeep just fine, it was putting the new motor in that we started running into issues. First issue: the damn special metric bolt to mount the 4.0 block to the brackets - not too big of an issue, but only ACE carries metric around here, and had to go there 2x before I got the right bolt . . . So motor goes in - tight - there was no chance of getting it in with tranny on - and fits like a glove for the most part.
Stage 2: Mount tranny to motor . . . supposedly this is easy if you re-use the T-5, but I HATE, I mean HATE the T-5, so I thought it'd be a great plan to go with the AX-15, which was available on '90s wranglers. the first AX-15 I got was a '93 with internal slave - I traded for a '95 w/external . . .which, created some clutch pedal issues. Back to the trans. - The AX-15 is bigger than the T-5, and I ended up "modifying" my tranny tunnel a bit, ok, a lot - basically cut from the access panel back to the firewall. :eek: Then, since the tranny is longer, had to cut the opposite way for the shifter . . . So what have I learned? a 1 - 2" body lift would've saved me some cutting, but not all. That brings me to the D300. I got a good deal on a AA kit and it worked really well - I am very happy with it. Once I finally got the t-case on (arduous task) I had to again "modify" the t-case shifter - torch and cheater - good to go.
That brings me to today: I had to modify the tranny mount from the AX-15 - the t-5 mounts weren't gonna work, and need to bolt them up to the tranny, modify the skid plate to work with the new mounts . . . should be good to go . . . EXCEPT I think my front driveshaft and Bell Housing are going to be arguing, which wraps up my story and leads me into Q&A: :cool:
bigwalton said:
Nice looking rig you got there... to start with 4" of lift, some 35s.... yeehaa!
Thanks! The Scrambler came with a 4" lift, which has yet to be installed as I wanted to learn the limitations of my Jeep first, but now it seems necessary. As far as 35's, I am not sure if they'll fit w/out rubbing - anyone? I plan on 33's, which is the biggest I can go to get the emissions done because they don't allow anything bigger than that on the dyno, then after the emissions I plan on 35's w/some rock crawler rims.
Alright that's ot for now - perhaps I'll start a thread in one of the other sections . . .
Aaron
Welcome to the board, I am pretty new here myself. I am on the board of directors for the Arkansas Travel Council, so if you need some propaganda to convince your wife that Arkansas is the sh!t, let me know. Trust me, she will have the time of her life, even my wife said it was okay to go to the national scramble as long as she gets to get her nails done and hang out in the spas. If my wife agrees to it that quickly, anybody will, she is absolutely the biggest prissy girl in the world. Hot Springs is noted as America's first resort, people came from all over the country to enjoy the amazing natural hot springs that were available... from celebrities to outlaws. The old bath houses are still in tact and well preserved so you really get a feeling of historical ambience just being in Hot Springs. What I think is really cool is that you can actually walk under the city, there is a walkway under the main road where the springs flow naturally, it's like an underground river. Very cool.
Anyway, welcome to the board, don't be afraid to take off 14 inches or more from the bed of your Scrambler, and have fun. :cool:
Tourist INFO
Thanks djgaston for posting this you are athe man we are looking for,want help us promote this event? Contact me at mulescj8@bellsouth.net JC :D
Email sent; I'd be glad to help out in any way that I can.
First thing we need to do is update the stinkin' banner on the side bar to reflect the new dates.
