I'm looking at buying an '82 scrambler in the next couple days...
I drove it today, everything seems solid, I just had a couple questions;
First, there was a constant fairly strong smell of exhaust for the ten minutes we were driving The car had not moved for a week, but I was wondering if this is something common, or something in the exhaust, or something to worry about?
Second, the brakes were, to say the least, soft. There was a solid few inches of push until anything happened, and even then it was far from effective. But they work. I have a '78 CJ-5 and a '67 Kaiser, and just sold a '94 Wrangler, and the brakes were all pretty solid. Is this a Cj-8 thing, or likely just a truck in need of new brakes?
Finally, there was a fair amount of play in the steering. There are some pretty large (and wide!) tires on the truck, so i'm sure that didn't help, but it seemed a little 'floaty' is the best way I can think to put it. What were the stock tires and rims on one of these? Would that make it feel more solid? I plan on going as stock as possible as a daily driver, no rock crawlers for me. Any tips?
Oh, also, converting the seatblets to three-point instead of lap belts; Can i drill through the top, seal the hole, and run a bolt through the roll bar so i can use them with the top off also? How about for the back seat? Do you need a custom roll cage for three point belts?
Thank you, this is my first post. Looking forward to the site!
, worn suspension bushings, etc. etc. Good thing is that most of it should be replaced anyway before really driving it, so you have a good chance of fixing it up nice.
