Holley Sniper with an automatic transmission
Super 8
Bozeman
MT
I was hoping to use the Holley Sniper on my 258 but according to Holley's website it will not work with kickdown transmission linkage. Has anyone found a solution to using the Sniper with the factor TF-999?
I have it on my Overlander with the TF999 and it works fine. But the linkage is slightly different than the left hand drive setups.
I know this is splitting hairs, but the TF999 does not have a kickdown linkage. It (like all Chrysler transmissions) uses a throttle valve lever. The linkage in question moves the throttle valve a proportional amount as throttle is increased until it has reached the full open position. This valve then increases the line pressure in the transmission causing the shift timing to change and affects the governor application (as well as increases the clamping force on the clutch packs). Proper throttle valve actuation is imperative as too much pressure can burn up the clutches and too little pressure can also burn up the clutches.
Thank you for the information. I need all the education on these transmissions I can get! I've had mostly manual transmissions or swapped GM drivetrains in my Jeeps. I really appreciate it.
I can - give me a couple days - i just followed the workshop manual instructions and the auto transmission guides
Hi Mancunian. Just ordered the Sniper. Any chance you were able to get any pictures of the linkage? Thanks!
The throttle valve linkage should be the same, but the throttle linkage is different.
Got more hoses in the way of mine than ag4ever
Couple thoughts=
The Sniper does not connect to the linkage for the TF999 - it just connects to the vanilla throttle cable, as long as you have a functioning throttle and TF999 then the Sniper should not affect the auto at all.
Mines a RHD too - although i can't imagine that would make a difference.
I connected the O2 sensor to the same point as the pulse line exits - ground off the pulse tube and welded a O2 socket. You can see that in the second pic.
What are you doing with all the emissions stuff? I kept the vapour canister and associated hoses but eliminated the pulse lines. I also installed a cat, figured the Sniper would keep it happy.
Oh - and follow the directions in the manual to set the linkage - they are a little counterintuitive - words clamp and rod seemed mixed to me - but i figured it out in the end. Again if it works now you should not have to mess with it just b/c of the Sniper.
Thank you. I owe you one!
I have a 258 with complete Holley setup and 999 transmission. How or what do I need to do to achieve proper kickdown/ down shift with the automatic transmission?
BB
I had a local shop completely rebuild all of the linkages which I thought were ok when it was put in. It wouldn't stay in park. After my mechanic ordered the correct linkage rebuild kit & installed it, it was night and day!💯🤙
Not sure this helps any but I have the holley sniper/tf999 setup also. Great combo imho
