How do I fix a rusted out seat nut/bolt?
Cincyjeeprs
Cincinnati
Oh
I have searched around a little and haven't found anything useful.
The rear mount locations on my seats are rusted out. These are the inserts in the seats that take the itty bitty reverse torx screws from the sliders. I will assume that I have to get in there and weld a captured nut or something, but is there a decent write-up you can point me to? I am much better at following directions than coming up with my own fixes.
Never seen anything on those, would it be easier to just weld in a bolt and use a nut under the slider instead? Just a thought.
My "easy fix" would be this: take a couple of 1" square (or so) pieces of 1/4" steel, drill and tap them some convenient size, say 5/16-18, and then weld them to the surface of the bottom of the seat. I don't think the 1/4" "tilt forward" this adds to the seat would be noticeable and it would save taking the whole seat apart to get in there to weld a nut in.
But Eric's solution is a fine one too and doesn't add a 1/4" tilt forward to the seat.
