Crossbones
Charter Member
- Richmond
- Va
How is you Scrambler classified on the title & what restrictions apply because
of the way it's titled??
Because of the way my title is filled out: "COMMONWEALTH OF VIRGINIA CERTIFICATE OF TITLE FOR A VEHICLE" ...YEAR 1981....MAKE JEEP....VEHICLE BODY 2D SDN....EMPTY WEIGHT 2740...GROSS WEIGHT (blank)....GVWR (blank)....GCWR(blank)....I'm restricted by VA. Code to the lowest bumper height regs. I need to take the title to DMV & try to get it reclassified from 2D SDN to "Pickup", "Sports Utility", or "Truck" and the EMPTY WEIGHT or GVWR to 4150 lbs. which is what I think the Scrambler is.
Even if I can get the title changed to this I'll still be over the max. bumper height, but a lot closer to it. VA. Code is GVWR 4,500 lbs. or less bumper height 28" max, GVWR 4,501 to 7,500 lbs. 29" front/ 30"rear, GVWR 7,501 to 15,000 lbs. 30" front & 31" rear. GVWR of course is set by Manufacturer's vehicle specs.
My title says the above, John N's says GVWR 4150, Grantshire's 6,000
Anyway my bumper heights are well above code & don't see a way to avoid
a ticket if stopped.
How's your Scrambler titled for GVWR and body type
Robert
Robert
