How long is a CJ-8 tub?
1x1_Speed_Craig
Simplify...
Greeneville
TN
I'm looking for a semi-accurate firewall to rear measurement. I did a few quick searches, but didn't find anything. Please help. :)
Thanks,
Craig
off the top of my head 9'-10"
No I really did measure and that is what it is.
9ish
yep sounds correct,
don't know off hand either, but when I make the crate for the GR8TOPS full hardtop, it is 9' pallet. So add a few more inches of rake on the windshield and then the cowl section. sounds right to me.
guess I could unpile the one in the garage in measure. :eek:
:) I just needed the measurement so I can start planning how to squeeze both of the CJ-8 tubs I got from Ted Wendel on my 16' trailer.
Craig
Craig, the best way to move/store them (don't ask my how I know....) is to stand them on their side. You can put them bottom to bottom if that is all you have to haul or put topsides together (flipping one cowl to tail) and store stuff in between for travel.
Truck
Truck
Good tip, Truck. In that case, I'll have to measure how tall the tub is. My trailer is 6' 4" wide on the inside rail.
Does it bang up the side of the body by hauling them this way?
Craig
They will fit, I've done it on my trailer a couple of times. Never had body damage, but one thing to help if they have the door hinges on is to throw a 2x4 under (best place is cowl and behind rear wheel well) to get it off laying flat on the trailer. Once on, I just strapped 'em together then strapped 'em down across the top (front & back) and it was all good.
Easy to store this way as well. You can place them on a piano dolly (C-clamped to tub) makes it real easy to move around and you can store flat against a wall. Did this in my garage for awhile, one against the wall the other between the single garage door space and they were easy to move around the garage when needed.
Truck
They are just over 48"s wide because a Jeep body or Scrambler hard top will fit in the back of a full size pick-up. :)
Carl
