How many "hail Mary"s will it take...
Several updates...
The XJ is back from the dealership, where they did the following:
  • Airbag control module relocation (Recall)
  • Fuel tank sending unit replacement (Recall)
  • Replaced rear main seal & front crank case seal. The Cherokee no longer leaves "tracks" in the garage.
I also bought 2 new transmission cooling lines (not knowing that there are 3, one of which I need to still get) to replace leaky ones. We'll do that shortly.
I also picked up a set of overpriced (but rust-free) doors just to get the interior door panels to replace, in particular, Mira's passenger one. I'm reselling the doors (driver door is VERY nice, but passenger is dented), but keeping the interior panels. They're hard to find for manual windows/locks, so despite being overpriced, they were located only 20 minutes from my house, so I can't complain.
Here's Mira's old inner door panel, which has been bedazzled with random sheet metal screws to hold the door pull on the door.
Here's her new replacement door panel:
I also rented a Bissell commercial carpet cleaner, and spent several hours (almost five?!?) shampooing Mira's old carpet pieces (which will be sold), and her new darker carpets, seats, and headliner. It's not perfect, but here's her replacement carpet after shampooing. Eventually, I'd like to look at a set of WeatherTech floor mats for the Jeep.
The POR-15 paint application you haven't heard about...
Mira's replacement carpet had some rust marks/flakes that transferred from the floor of the donor vehicle, and I don't want it starting rust in her clean, rust-free XJ. I considered Dynamat or Eastwood Thermocoustic Barrier, but don't have the money for either right now (spendy). So, I used a 4-oz. can of POR-15 paint to cover the rust marks prior to reinstalling in Mira's Jeep. It may be overkill and/or OCD, but that's how I roll.
Mira changed her own XJ spark plugs today.
A previous owner had installed Champion platinum plugs (which I heard don't work very well in Jeep 4.0s), and the gap varied from 0.048-0.055". They were supposed to be 0.035".
The new, properly-gapped NGK "standard" plugs made the 4.0L run much more smoothly, but we still have a slight backfire when revving the engine. We'll have to get it into a shop in the spring to get that checked out.
The biggest news...letting the cat out of the bag...
After careful consideration, we have decided to keep Mira's XJ 2WD for now. Call it a "Prerunner". Call it a "Mall Crawler" (I'm sure it'll live up to its name). The bottom line is that we already have a solid driveline in this XJ, and she won't be driving it too horribly far once she gets her license, as her mom & step-dad just bought a house that is basically across from the high school. We can always convert it to 4WD down the road, should we want to do so.
We're also on somewhat of a deadline now (however, this did not factor into the 2WD decision). A friend is setting up a Jeeping weekend in Grayling, Michigan in June, and we're going to try to get Mira's XJ ready to go by then. It'll be a lot of 2-track trails, with a little more difficult stuff (relatively speaking) sprinkled in.
So on to the actual updates (somewhat anti-climatic, given the polar vortex we have been so fortunate to be experiencing here in Michigan). My free time has also been split with rounding up key parts for my Jeep FC170 project.
Mira's interior door panels, inner quarter panel trim pieces, and inner rear hatch panel are removed, and ready for a coating of Eastwood Internal Frame Coating once we get a little warmer weather (holding our breath).
My girls earned some extra money a couple weeks ago doing a "power part-out" on this inexpensive '92 XJ 2-door. It was in & out of the garage in about a 24-hour timeframe. We kept a handful of parts for Mira's XJ, most notably a set of 3-month-old rotors and calipers that had been installed on the XJ shortly before it was parked due to rusty floors and frame. Mira needed front brakes, so this worked out perfectly, and cost us nothing after parting out the Jeep.
What's up next?
  • Apply a coating of Eastwood Internal Frame Coating once we get a little warmer weather.
  • Reinstall the replacement carpet/interior.
  • We have some new Moog upper control arm bushings ready to install, along with low-mileage drag link & tie rod, and upper control arms that I pulled from my (former) '05 LJ when I swapped in 1-tons and long-arm suspension. We also have some new adjustable lower control arms from TeraFlex, who sponsored Mira with these. We plan to knock out all of this front suspension and front brake work soon, and put a coat of paint on the dead float 2WD front axle in the process.
  • Finish up our JCR Offroad (another of Mira's sponsors) DIY front & rear bumpers.
We have a lot to do by June, but I think we can knock it out.
(Written by Mira...)
With the weather getting better, we got some work done on my Cherokee today. We got the passenger door panel removed, the new passenger side tweeter speaker installed, and the donor inner door panels pulled and ready to install in my Jeep. :D
First we took off the inner door panels to be able to install the tweeter speaker on the passenger side. The previous owner screwed in the armrest with like a billion screws, so that was tedious, but we got them out and the door panel off. We installed the tweeter speaker on the passenger side (the driver speaker was already on) with no trouble at all. We then moved on to the donor doors and took my "new" door panels off. We're waiting for the weather to get warmer so we can use some Eastwood rust-proofing inside the doors before installing the replacements.
Nice work!
Keep up the good work. :wave:
Thanks guys! :cool:
I had the day off work today with my girls, and made some GREAT Spring Break progress on Mira's Jeep.
First, I started late last night repairing the extensive rust (note: tongue-in-cheek...this equated to light sanding), and threw on some POR-15. Normally, we use Eastwood paint, but the brush-on POR that we already had worked decently-well in this case. I'm still not a real fan of the stuff, but hopefully, it'll keep her floorpan in good shape for a decade plus.
(Not pictured) We got an early start this morning, and swapped out the 35-tooth speedometer gear for a 34-tooth gear I had from my '05 LJ to correct for the larger tires. The stock tires (confirmed with the dealership via the VIN) were P215/75R-15s (27.7" tall), while the 31" BFG KM2s measure an actual 30" tall. The speedo should be fairly dead-on now.
Mira then got her "new" (replacement) door panels reinstalled. The original passenger one was a little buggered-up by a previous owner.
Mira then threw a second coat of POR on the floor to seal it up. Carpet and seat reinstall will happen fairly soon (perhaps even this weekend).
We also replaced Mira's front brake pads & rotors with some new ones from a parts Cherokee we bought a couple months ago. They had about a month worth of use on them before the vehicle was parked, and were in almost new condition. This was Mira's first experience with brake work, and she realized how simple it really was.
There's no doubt Mira is my child...she REALLY enjoys making Jeep parts pretty.
Today, we scuffed & primed her windshield wiper arms, "new" (low-mileage from my old '05 LJ) tie rod/drag link, and her new TeraFlex adjustable lower control arms, just to make them match her other underpinnings (TeraFlex sponsored her with these LCAs). We primed them with Eastwood Extreme Chassis Black Primer, and will top-coat them with Extreme Chassis Coat Black Satin (Eastwood also sponsored her).
We got Mira's new (to her) front carpet reinstalled today, along with the front seats (not shown)...looks great! Mira then proceeded to drive around the property (solo) for about 15 minutes. She's a good little driver!
Congrats MIRA !!!
And r you really going to slip a pic in of a FC and not talk about it,or am I the only one who doesn't know ?
Congrats MIRA !!!
LOL. Mira thanks you (she's sitting right next to me).
The FC170 "Patina Rod" is dear-ol'-dad's (my) project. Build thread HERE. In a nutshell, the FC cab will be mounted on a 2005 F350 cab & chassis frame, and run a 2005 F350 Dana 60 front/1999.5 Dana 80 dually rear, and be powered by a low-mileage 1999 Cherokee XJ 4.0L/AW4/NP-231.
build thread... Build Thread... BUILD THREAD!!!! :drool:
Good job Mira, by the way.
Nice work Mira. My daughter still has her Jeep she and I built when she was 14, over 20 years ago (won't say how many over). It;s sitting on 40 inch tires now. Keep up the good work. :wave:
:thumbsup: Thanks Toby.
Small update...Mira and I got the following done on Friday:
  • Replaced broken/cobbled-by-a-previous-owner vent tube that runs from the PCV to the intake manifold.
  • Replaced bad battery temp sensor that was throwing a code ("Check Engine" light). A previous owner had pinched/flattened the wires when they removed and reinstalled the battery tray.
  • Replaced bad post-cat O2 sensor with a new Bosch unit.
On to more exciting work the next weekend I have with my girls. Oh, and hopefully there's a late-model 2-door XJ in-the-works for Mira's little sister, too (more to come).
Craig and Mira
P.S. - I found this today written in the dust on our parts Cherokee (I have no idea when she wrote it). It's the only pic I have for today. Apparently, Mira "rock & rolls all night, and part of every day." :rotfl:
