- Ashburn
- VA
I think that's it. If it's a late 81 the 3 holes are already there, just cut off the shorty towers. Early 81 doesn't have the 3 holes, but I can make a template off of mine and send it if you want.
I also have a set of the 81 lower spring plates if you just want to go with the existing brackets. I think the shock is shorter, however.
The current plan is to swap the towers for the longer ones. I will look to see if the holes are there or not. Thanks.
