How to drill holes in windshield frame and sheetmetal
JohnnySix
Arlington
VA
I'm installing the windshield channel for a bikini top and also installing the wooden side rails. I want to do this right (goes w/o saying) and keep everything looking clean and tight.
My questions are:
1) Is there a special drill bit I should use? And at a certain RPM range?
2) After the holes are drilled, should I paint/treat the newly exposed metal to prevent rust?
3) Any other pointers,tips, tricks, etc.?
Thanks for the help.
Use a good sharp bit - I think the ones I have are colbalt and intended for drilling thru steel. Go slowly and use a drop or 2 of oil (sewing machine oil, 3-n-1 oil, etc) as you drill. This will reduce friction and heat. Don't push the bit til it starts to smoke or change color. Should go pretty easy.
A drop of paint or primer around the hole won't hurt either.
:cheers:
Thanks for the tips. Took your advice and came out real nice. Did the bikini top, now moving on to the rails. :fingerscrossed:
