Hydraulic clutch install
JEEPTHRILLS
Swapped Auto for manual with new Master, Slave, line, and clutch. Now I seem to be having a problem with the slave not having enough throw to release the clutch completely. I have bled it to death...but it wont get better. For the meantime I "added" a 1/2 inch spacer between the slave tip and clutch fork, it works but there is no freeplay...Need a better solution...any ideas??
Ran into the same problem on a friends cj 7, put a spacer in like you did. When you say you have no free play where are you checking it at ? The pedal or the clutch fork ? When I was an automotive mechanic we used to try for 1/8 in of free play at the fork .You may have to shorten up the spacer. If this doesn't work it's possible the slave cylinder doesn't have enough travel or the fork or throw out bearing aren't right for the application. I saw on Novaks web sight that they sell slave cylinders that may cure your problem . Hope this helps.
I am in the process of installing the Novak kit on my jeep, using an sm465 transmission. I used a master cylinder from an old YJ 4 banger with manual trans.
The Novak slave cylinder has thread adjustments on the slave tip, as well as mounting slots that you can use to position the slave cylinder forward or backward about an inch, so there is plenty of adjusment at the slave cylinder.
Couple of things to consider:
1.They supplied a bracket and clutch fork, but you have to supply your own throwout bearing (they have a Novak "Guide to Clutches, Linkages, & Bellhousings" to get the spec from). Regarding adjustment, in the instructions it says "if you have chosen the wrong throwout bearing, no amount of adjustment will remedy it."
2. The original cj master has a hard plastic line, whereas the Novak has a threaded hose end. I have a brass compression fitting that I will use to connect the two, once I decide exactly where to cut the plastic line.
3. At least on mine (LT1 motor), the Novak slave hose would have been in conflict with the stock exhaust manifold outlet. I would not have this problem if I had center dump headers. Anyway, I just got a 90 degree fitting to fix that issue.
Maybe it would help if you could provide some more details on your drivetrain and maybe some pics.
I should know by this weekend whether or not my setup will work Keeping my fingers crossed!
-Mike
details are simple...factory 258, and a used t-5.
there is no play at the fork...I actually had to take the bit it had with the spacer...and then some. The clutch is a brand new Napa unit with included T/O bearing...which thinking back looked too thin...but the papers from the clutch kit said "the installed height will seem different, but it will not effect performance". Guess they were wrong.
I have tried several thickness spacers.....the one that left a little play at the fork wouldnt disengage the clutch. I actually have the T/O bearing tightly buried into the P/P to obtain enough throw to disengage.
how long did your buddies throwout bearing last? Were you able to get any freeplay out of it?
I set it up with that 1/8 in of free play I was talking about so it's holding up o.k. but it could us some more travel at the pedal because you have to hold the pedal all the way to the floor to get it into gear, the pedal also gets pretty stiff towards the bottom and after driving around all day your leg gets tired . I think I'm going to switch it out for one of those Novak ones. Now that I think about it I need to measure the throw out bearing because it would be cheaper to put a longer one in if I can.
i put a call into Napa...he is going to call the manufacturer, and see if this is a common occurance. I think easiest for me (not having a lift) may be to swap from my 7/8 slave to that Novak 3/4 in bore. With the 7/8 master...may give a little more push.
wouldnt it be easier just to swap slaves?? I know I am trying to avoid pulling the tranny again!!!
Sad part is that the pedal is just about perfect...I really like where it grabs off the floor...just wish the Pressure plate fingers werent being pushed.
Yes , I think it would be easier to just swap the slave ...but like I said the farther the pedal goes down the harder it gets wich leads me to believe that It may be losing leverage. Pulling the trans isn't a big deal to me , compaired to pulling a trans on the heavy equip that I work on it is a piece of cake.
I used to be a Mack fleet mechanic, It isnt a big deal...just sucks on the ground...especially when there is an easier fix.
Luckily mine is uniform tension through out the throw.
If you worked on Mack's then you have done some tough clutch jobs !
I used to work for a concrete company and I always hated pulling them tri-plex's with the P.T.O. clutches , WHAT A P.I.A !!!:angry:
I'm swapping out an auto myself, for an NV4500. I have chosen to go hydraulic as well.
Bought a Napa clutch master for 4cyl CJ, bought a Napa slave, but went with some pieces from Advance Adapters to put it all together.
I bought the line (braided stainless), a fitting to adapt the line, a tapered threaded rod (more on this in a minute), a shifter (the tranny I bought did not have one), return spring, and a wedge.
Kit # 716331
The threaded rod replaces the rod that came with the Napa slave, the tapered end towards the slave. The other end threads through the wedge and the wedge makes the contact with the fork. Almost infinate adjustability, well not infinate, but enough to adjust it quite a bit.
http://advanceadapters.com/product/2366/%28P/N-716331%29-JEEP-SLAVE-CYLINDER-KIT.html
I can tell from playing with the spacers that there is no way to get any free play, and still have the clutch release. May go swap the slave at parts store...might be defective???
any thoughts??
It soulds like you're over-centering the pressure plate-
We finished the connections on mine last night and bled the system.
Works well, although the Novak slave cylinder bracket has a very slight bit of flex too it, but not really a problem, just something we noticed.
I can post up pictures later if you want, but not much to see.
BTW, I incorrectly stated that I was using a CJ master cylinder...it is actually from a YJ.
Whats the difference between the two? Does the YJ have a longer stroke? I measured the CJ's throw at the pin connector to the pedal, it is just about 2-2.25".
Have you had any more luck with the clutch ?
Swapped the slave...no difference. Napa's only answer is to get me another kit from the same manufacturer. I am not sure what to do next...Since it is my DD...it is being driven as is for now.Luckily my commute is only 3-4 miles, but I do have a big drive to LA in a few weeks for training at my new company...and I will be stuck there for 3+weeks, so I really need a solution. If I dont come up with something soon...the TF999 may go back in.
I'm not sure about the differences. I bought this one from Ted Wendel, one of the local guys on this site who usually has most any part you may need. He has taken apart dozens of CJs and YJs, so I'll ask him if he doesn't post up here soon or if no one else replies about that.
I will measure the throw for you tomorrow.
