I bought another scrambler !
Can someone help educate an non gear head.
Why is rack an pinion steering bad? What is the better alternative and why? After a quick wiki read, I'm under the impression that rack and pinion means there is a circular gear that moves a straight bat with teeth back and forth.
Second, what is bad with the column shifter /& floor shifter, what are these exactly? A typical stick shift for a manual or a floor shifter for an automatic transmission? and once again, what is the better alternative and why?
Thanks for the help and sorry for the noob questions but I have to learn somehow. I really wish I had spent more time in a garage as a kid.
Oh and why is a spring over 2.5" lift bad? what is better, why?
These are good questions but probably better to post them in their own thread so as not to hijack Jim's. :cheers:
Did alittle more this afternoon
Removed the OEM rockers. , only broke 1 bolt on each side. !!!
Removed tailgate and added a cj7 gasket that I saved. !
I'm going to borrow a DA sander from my painter and start working on the floor soon. !!
Had to drill out one broken torx
Cleaned up the drivers side
Sent from my iPhone
This is a perfect example of "Diamond in the rough"
Looking good!
And I'm still trying to finish building my shed so that I can build my garage so that I can work on my Jeep....I hate you! But you are doing a great job with this one and I applaud your vision to see through that thing that you bought and turn it into this one. Outstanding!
Thank you , that means a lot !
Merry Christmas !!
Sent from my iPhone
