IAFFCJ 81 Scrambler
So i have been trying to figure out the skid plate and traction bar setup for a few days now. Just couldn't seem to see it in my head. So i built one out of some scrap wood today. Looks like i can have a flat plate if i drop it 1.5 inches below the frame. So the positive note is that it looks like i can go ahead and paint the frame without having to redo much when i build the skid plate.
FYI....that wooden skid plate won't hold up very well.:thumbsup:
Lol so much hate. I think with enough coats of marine grade poly it will hold up great.
Spent some time in the garage today. Not as much as i would have liked but had to run some errands this morning and it ate up some time. I did manage to get the engine and trasmission pulled, the last bits of some brackets ground off the frame, final welding of the motor mounts, and pressure washed the bare frame so it should be ready for paint this weekend.
I also called advanced adapters to order some new yokes for the atlas. Great customer service from those folks they were even able to look up this specific trasfer case to be sure i was getting the right stuff. New 1350 yoke for the front and 1350 cv flange ordered.
Plans for the next few days is depending on weather is to get rust encapsolator on the frame, internal coated, and chassis black for the top coat on the frame. I am also going to try and pressure clean the engine and transmission sonit can go right back in when the frame is dry as i am rapidly running out of room with everthing pulled apart again.
Really looking forward to asembling parts without knowing they are coming back apart.
Also figured since yall likes my skid plate so much you may want some specks on my traction bar. 20170301_131532.jpg
Thats special high strength 1 inch painters tape right there. Highly desirable. :rotfl:
That thing is going to be solid! :thumbsup:
Nah, looking good Jake! I have to get back on dads, I bought some stuff yesterday for his but ended up working on my blue one. :angry:
Spent a little time in the garage this afternoon working on getting parts ready for paint. Mainly worked on the hood and moving parts from storage to the garage.
Hood has a few dents ive started working them out with hammer and dolly. Not doint too bad i dont think for not knowing what i am doing at all
Well no pictures for today but I did manage to get some work done.
MORE steering box mount figured out, will need some spacers to take up the room that the spring hangers would fill under the bracket due to my full width axle set up.
Tapped up all the holes in the frame and got the internal frame coating sprayed (for those who have not used this it gets everywhere and does not come off anything) - I guess that it what makes it good at what it is for.
Pulled all the tape and scuffed up all the areas that i had already put rust encapsulator on.
I was going to try and get a coat of paint on it today but was running low on time so I called it there and will try and get rust encapsulator on early on Thursday so I can get at least on coat of chassis black on that evening. My goal is to have the engine and transmission back in the frame by this weekend.
Took advantage of the nice weather today as it looks like its not going to last. I would like mother nature to make up her mind it makes planning much easier
Soaked the engine and trasmission with engine cleaner. It came out pretty nice should mek working on it that much nicer
Got a good full coat of rust encapsolator on the frame early so i could top coat it before the day was over
While i was waiting for that to dry. I put some paint on the sliders. Not sure how i feel about it. I like the red jusr wish it matched my rims a little better. Oh well guessnim still looking for the right accent paint
Delivery from advanced adapters showed up today also so i swaped out yokes for 1350s and a flange in the rear
And then managed to get the frame top coated with chassis black. Being that it was supposed to snow in the morning. 70 today and snow tomorrow ugg. So i had to make room to get the frame back in the garage.
Engine and trasmission baxk in the frame today. Atlas fully bolted in full of fluid and ready to go.
Corvette manifolds showed up today. Pulled the truck manifolds and bolted on the corvette ones. Turns out there were 3 broken bolts on the manifolds drilling them oit will be nerve racking. I think there were some folks asking about the manifolds so i took a bunch of pictures.
And passanger side
Got a few small things done as well. And it turns out there is plenty of room for my 1350 i joint at the case so thats always good.
