If I didn't have bad luck, I wouldn't have luck at all!
mikecj8
Nevada City
ca
Somehow my Scrambler has been jinxed.....One episode was where I had my transmission in a shop only to have it held "hostage" while the shop owner battled in divorce court. My most recent dilemna ended today. I took my Scrambler to a "master certified mechanic" at the end of April to connect my motor swap harness to my Jeep harness. Was told, " no problem". I drove out there daily at the guy's request and soon found "no progress" but, I was told each day " Yeah, I didn't get to it today, so come out tomorrow" Well, that ended yesterday when I finally had enough and told him that I was picking it up. So, I called him today to get the Jeep off the rack and that I was on my way. Oh, and he was "gracious" enough to not charge me........So, I got a birdsnest of wires to deal with. I plan on doing as much stuff I can this weekend, then maybe hauling it 150 miles to a wiring outfit that my buddy has used...................stay tuned:D Here is a pic as it sits today
What sort of engine do you have in there?? That would help on what to wire up.
You can get the basics done frorm the from the ignition to the starter pretty easy. Lights and otehr stuff can happen after that. I would start with your ignition switch hot wire to the battery and then go down the line from there to the ignition module to the starter and distributor/coil.
If you look up Autozone on line they have manuals you can look up for your application.
http://www.autozone.com/servlet/UiBroker?UseCase=RG001&UserAction=viewRepairGuideYMMEYear
You might be able to find out what goes where from there?? Good Luck!
TK
mike ..u should have brought it to arkansas..i would have wired it for a case of sam adams....
The time it spent in this guy's shop, I could of probably pushed my Scrambler to your front door!! Keep your porch light on...:D
TK
Tom:
It's a 2000 6.0 Vortec motor. I am a marginal mechanic at best. I can do the basic stuff but wiring always intimidated me. I envision my wiring work frying something important............Thanks for the tip and link, I appreciate your help.
where did you get your harness...my street and performance harness only had 5 wires to hook up???
Speartech did the work on the harness. I've got alot more than 5 wires to hook up. The wiring under my dash was already a mess, the harness attached to the firewall got oil soaked all over it so, I have to clean it off to see what color wiring is in the loom...........I could go on and on. Really, though that is why I am shaking my head at the attitude of the mechanic. It seemed relatively easy to hook up, especially if you make a living at it, like he does! For all he did and left me with, I have my work cut out for me!!
This Jeep has been a lesson in frustration. I am now back to basically starting over with the motor mounts. They were put in too far forward. So, I talked to the guy that did the work and he will move them back. At the same time I hope to position the motor so the driveline fits. Novak swears this is possible............we shall see. So, my Jeeping Summer is shot and I will have to Non-op my Scrambler since the registration is due. I seriously was at the point of throwing up my arms and quitting, but after a day of relaxing (hard to do in 112 - 113 degree heat) I plan on moving forward step by step...........
Keep yer chin up, pilgrim. :D
You do seem to get more than your fair share of problems with getting work done. You must have been a bad person in a previous life - karma is catching up to you. :D Just kiddin.
Bring it out to Virginia Beach, I know a great mechanic. :D
Man, I wish I were there to help...
Do you know that the stock Scrambler wiring was original? Getting a Factory service manual and any instructions from the wiring folks should be enough to work through to get things connected up with a lot of patience.
Did you pull the original engine yourself? Was all of the emissions junk there to start with? The first step in an engine swap should be to pull the computer and all of the associated sensors and wires. Once you get down to what it takes to run the engine without all of that junk, there's actually very few wires to worry with. If you check out the engine bay of someone who's done a carb conversion (weber or MC2100) and a dizzy upgrade (HEI preferably) you'll see what I mean.
Sorry to hear about your engine mounts too... at least the guy is being good and getting you hooked up right.
Keep looking at the big picture and remember that you'll have a killer Scrambler when it's all done.
I just have to shake my head and laugh instead of the "why me" pity party! :D The most frustrating part is that I keep finding these guys that all have thier own way of doing things.........or not doing things........as was the last guy. But, they all don't seem to be on the same page. The instructions I got from Speartech went by the wayside, the Novak suggestions on engine placement got shoved in a box..........etc. So, unless I babysit them and look over their shoulder day in, day out. I keep getting one step forward and ten steps backward. Before I moved up here, I had a buddy that had a shop and he and my other friends would have a wrenching party and get things done. Now, I am 2 hours away and can't do that anymore.
I did pull the motor out myself. It was a AMC 4 cylinder motor. The existing wiring harness under the hood looked stock. The wiring under the dash was pretty hacked up. The smog stuff was there for that motor.
Mike, I hate to sound harsh but 2 hours to get something done is trivial, I'd either invite the crew up or rent a truck and trailer and go visit, I've got a 2 hour drive for ANYTHING other than the most trivial parts. For example, to refill a powertank is a full day's vacation since it has to be a weekday, 2 hours drive each way and hope that either the hydro is current or it can be done same day (two different businesses).
might be worth considering making the trip to get the jeep done right, based on your experiences locally.
Trust, I appreciate your response but it is not that easy. My friends shop is now in the possession of his ex-wife...... So, I could round up my friends but, we would have to work on it by the roadside! Today, I'm borrowing some stock tires so my Scrambler will fit on a trailer to take back to the shop that put the motor mounts in. Once there I plan on spending my time and making sure that the motor is far enough back and that I have driveline clearance.
Ah so, I understand why now, don't think I'd want to mess with it either under those conditions. Good luck.
Well, the "luck" continues.............My '03 Honda Pilot developed a noise in the tranny two days ago. Dropped it off at the dealer and got the news today.........3rd and 4th gear are gone.........$3k+ to repair...recall was for 2nd gear..........no warranty as I bought the Honda used from private party. So, now I about ready to bang my head on the keyboard..............:(
Put in a granny T18 .... OH, better yet a TH400 and an Atlas :D :cool:
Sorry man, just trying to lighten the mood... that just sucks.
Go to http://car-part.com and start looking for a used unit. Even there they are pricey (I looked), but you might be able to save a grand or so just installing (having installed) a used unit, yourself.
Easy on the keyboard so we can continue to track your progress and hopefully help.
You must have upset someone pretty powerful. Sorry...hope things start to improve.
Paul
Paul
Paul, Thanks for the link but, it looks like I am going to have to bite the bullet with the dealer. I checked with a independent shop and their labor rate would be at least $600.00 I don't have the space at my place to tear into the pilot as my Scrambler is already taking up space. I rent a townhouse which limits me as to what I can do there. Anyway, I really appreciate your help. I'd go buy a lotto ticket, but I'm afraid I might get hit by a car crossing the street.......:D
Mike - Sorry to hear about the run of bad luck!:( :mad: Hang in there and things WILL turn around for you sometime!
mikecj8 said:
This Jeep has been a lesson in frustration.....I seriously was at the point of throwing up my arms and quitting, but after a day of relaxing (hard to do in 112 - 113 degree heat) I plan on moving forward step by step...........
I can relate to a lot of what you are feeling here. Sounds like your mechanical skills and mine are about equal, and the rebuild can be pretty intimidating, but I think it is important to remember that the Jeep is just a hobby to enjoy, so don't get worked up about it....just keep moving forward as time, $, and motivation allows and someday you'll be driving it around!
-Mike
