It's all the little stuff that's expensive. I just placed an order from 4WD Hardware yesterday, and a lot of this "little" stuff added up to $550 really fast.
If you're looking to go that route, I'd look for a good-running CJ-7 (maybe with rough frame/body) as a core vehicle, then buy a new or used Scrambler body & frame. That way, you'll have 90% of all the little parts you'd need. I'll be doing this with my '86 CJ-7. I picked it up for $800. Body & frame are bad, but it runs decent, it was a single owner, and it has the OEM Dana 44 rear axle. After selling the hardtop, soft top, and doors (which I won't be using), I now have less than $400 invested in it, not including the used replacement frame I bought for it already. It'll get a YJ tub, most likely.
Again, my Scrambler project has experienced scope-creep with all the little stuff I'm replacing. I'd guess it would run upward of $15K to build one from scratch. I'll probably have $11K+ in mine when it's done, and I started with a rust-free OEM frame.
Craig
