Interesting question
prismfisher
Hamilton
Mt
I am fairly new to the site so if this has been beaten to death in other posts..... never mind. I was just wondering with all of the websites and catalogues to get every concievable part for a Scrambler, how much it would be to build one from scratch or with nothing to start. All new parts and if you did, how would you go about getting it registered. I am sure some Mr. Got Rocks could commission such a job. What would it cost.
You're probably looking at $4K just for a frame and fiberglass or Kevlar body and fenders/hood. At least another $1K if you go with steel or aluminum.
Drivetrain would be the biggest variation in cost. Since a truly new engine/axles/etc... could cost a fortune, most people would probably go with rebuilt stuff. A stock drivetrain could cost as little as $1-2K give or take. A V8 conversion and bigger axles would definitely run more.
You also have the wiring harnesses, lights, cage, interior, dash, gauges, gas tank, tires, wheels, etc... you could easily double the totals so far with all the miscellaneous stuff you'd have to get.
I've toyed with the idea myself. It'd be a great way to build a like new Scrambler exactly the way you want it.
As far a registering it, I'm not sure. You may be able to register it as a kit car or they may require you to get a VIN from elsewhere, it would probably vary from state to state.
With the exception of the engine, you could probably do the whole thing right out of a 4 Wheel Drive Hardware catalog. I don't have the time or energy to add up all those prices, but I'm guessing for the same amount you could buy a new Rubicon, and not have all of the registration problems.
BTW - Before anyone tells me a Rubi isn't as cool as a Scrambler: A jeep built with modern parts out of a catalog isn't as cool as a Scrambler, either.
It's all the little stuff that's expensive. I just placed an order from 4WD Hardware yesterday, and a lot of this "little" stuff added up to $550 really fast.
If you're looking to go that route, I'd look for a good-running CJ-7 (maybe with rough frame/body) as a core vehicle, then buy a new or used Scrambler body & frame. That way, you'll have 90% of all the little parts you'd need. I'll be doing this with my '86 CJ-7. I picked it up for $800. Body & frame are bad, but it runs decent, it was a single owner, and it has the OEM Dana 44 rear axle. After selling the hardtop, soft top, and doors (which I won't be using), I now have less than $400 invested in it, not including the used replacement frame I bought for it already. It'll get a YJ tub, most likely.
Again, my Scrambler project has experienced scope-creep with all the little stuff I'm replacing. I'd guess it would run upward of $15K to build one from scratch. I'll probably have $11K+ in mine when it's done, and I started with a rust-free OEM frame.
Craig
Sounds good
I appreciate the thought. I wasnt looking to do one for myself. My 82 is enough project for me. I am looking forward to getting it worthy of posting here. I was just wondering what it would take.
I agree with the statement that a new Scrambler built out of all aftermarket parts isnt a REAL Scrambler. I believe part of the misitque of the Scrambler is the stories it has generated over 20+ years of existance. We have had ours in the family for almost 18 years and we used to use it to haul elk out of the hills in Colorado and Montana. Most ever was 3 I think..... of course dressed and quartered already.
cost?
A lot would depend on several things:
Body-Fiberglass,steel,or alum.
Frame
Drivetrain: motor,transmission,axles,etc.
If your going to have a shop build it,then plan on spending in the $28,000 to $35,000 range for a turn key Scrambler with new parts,price could be higher depending on labor rates.As far as getting it registered that will vary from state to state,some states it's not a big deal and others it can be a huge PIA and take months of calls and paper work-Then if you have emmision testing,trying to get it passed could be a headache also,if they register it as a 25 year old rig then it may pass without any trouble,if they register it as a new rig then it might have to pass emmision testing for new vechicals..........JC:D
Prismfisher,
Had an '8 for 18 years in east Tx and it isn't a rust bucket. Amazing!:eek:
That alum. body may be the trick?
cost of build from scratch
I worked it out when my 82 caught fire at $13000 using selected used parts and a donor to feel in the little stuff.
The aluminum body is VERY worth its cost., just measure things real carful and scrib your marks in to the frame as majic marker washes off when the frame is degreased.
