- Dexter
- MI
This was actually from last Thursday, but I haven't been on here since to post about it.
Drove the postal in to work. Left home a little earlier than normal (always easier to get up and out on a day I know I'm driving the Scrambler
) and my drive is almost entirely backroads and the first part is through woods, so it was dark in the shade.
Always trying to be safe (like anyone could miss a white Scrambler on 4" of lift and 33s) I put on my headlights and thought to myself "I have to remember to turn those off..."
You know what happened, right?
Came out of work and 9 hours with headlights on is enough to drain even a brand new red top. Go back in to work, find a guy with cables (I didn't want to leave stuff in the Scrambler at work when it's topless, I'm now broken of that thought though).
Jump the Scrambler, coworker leaves (we're about the last two there).
Now you have to know (people who have ridden with me know this well) that my alternator belt has ALWAYS had a squeak to it on startup when cold. It's a Mean Green alternator with 8k miles on it and I've replaced the belt twice. No amount of tightening will stop this squeak on cold startup. Belt dressing helps for a bit and then it's back. I've given up on it and considered it part of the character of the Jeep.
Anyhow, as I pull out of the parking spot, the squeak turns into an unholy scream, which it does from time to time but usually goes away as soon as I let off the gas. This time it stays... great, so I need to tighten the belt and I can't turn off the engine because it's not got enough juice to restart yet...
Ok, I can do this with the few essential tools I have hidden under the rear seat... so I pull over and manage to get it a little tighter without cutting off any more fingers.
Get in, no screaming belt, I get on with the drive home.
About two miles down the road, screaming starts again. Pull over, get out and lift hood, screaming stops. Annoyed, I reved the engine and no noise. Ok, back on the road.
Driving down the road (about 45 MPH) a mile more, screaming starts again... sounds a little different though. Pull over in a parking lot and get out to pop the hood. I notice that dreaded burnt electrical smell (the next few things happen rather quickly as I want to find the source of the burning)... as I walked to the front, I noticed the noise getting quieter... it's not the alternator... walk to the side of the Jeep, the noise is coming from underneath this time... uh oh...tranny? Bend down... the starter (also a Mean Green unit) is smoking (it's covered in oil of course) and is obviously the source of this new noise, stilll engaged with the flexplate.
Stand up, kill the key... engine still running strong... CRAP... pop the hood and pull the 12V wire to the HEI...engine starts to die, than catches and lopes along, about to stall out... CRAP run around and unscrew the positive cable on the Red Top (thank God I switched to the marine battery terminals with the wingnut connections!!!)... engine dies. Look, with extingusher in hand and find no fire...WHEW. Starter still smoking lightly.
Look at possible causes, find the starter relay to be blazing hot and the switched (from the key) wire to it with all the insulation melted off...
What had happened is that the switched wire to the relay shorted out to the positive feed from the battery, energizing the relay and engaging the starter until the battery was pulled.
The spot where they shorted was inside the stock wire loom and for some unexplained reason, there was a butt splice hidden in there that was done very poorly and covered with duct tape. I imagine that the splice finally got bad enough to heat up and melt through the tape and the insulation on the 12V feed, causing my nasty little problem. I should emphasize that everything looked COMPLETELY stock as it sat with the loom in place!!!
I pulled the loom off, separated all the wires, electrical taped the sketchy spots, cut off all of the exposed switched wire (from the short to the relay) and got clean wire to loop around the relay terminal. After doublechecking for any potential issues (and expecting there not to be enough juice in the recently drained battery from my short drive to actually turn over the engine and the still hot starter) I reconnected the battery and turned the key... she started right up and the starter disengaged as it should!
After looking around for any further problems and convincing myself that the fix was indeed enough to drive home on, I headed home.
Fun stuff... I'm not driving it again until all wire loom has been removed and all wires inspected. I'll have to rework the wires to the starter relay and I think I'll take my sweet time and do as many as I can the right way and the right length, run where I want them. Obviously, this is much easier since I have the HEI and MC2100... but still.
I wanted to share this mishap, because I'd have had to tear into the wire loom that otherwise looked just fine to keep this from happening.
On a side note, I'm now a VERY happy Mean Green and Optima customer! I can't believe that there was enough juice to start that thing after the short drive I took to where I had to kill the engine...
) and my drive is almost entirely backroads and the first part is through woods, so it was dark in the shade.Always trying to be safe (like anyone could miss a white Scrambler on 4" of lift and 33s) I put on my headlights and thought to myself "I have to remember to turn those off..."
