- Dexter
- MI
If the frame is in great shape and he has receipts to back up what he claims in the ad, I'd be all over it (if I were in the market and could spend that on one).
FYI, a full float kit doesn't resemble either two piece shafts or one piece shafts. It has a shaft with no flanged end on it that goes into a hub, just like the ends of the front axleshafts, that you can lock into a hub with a 4x2 - 4x4 knob (also just like the front axle). The hub is supported completely by bearings, so therefore the weight of the vehicle on the rear axle is completely supported by the bearings. This means that the ONLY load that the rear axleshafts see is the torque from the tires and ring gear, there's no bending due to the shaft supporting the weight of the vehicle.
The comment about towing that the seller makes is because you can unlock all of the hubs (since you have one at each wheel) and the drivetrain is completely isolated for towing.
Click this to read a description and check out this picture, you can see the flangeless shafts, spindles, hubs and lockouts really well:
jpdeuce said:...does that full floating kit definitely mean it's one piece in the rear?
