Intro
CopeDog
Boerne
Hi All,
New member, first post.
Unlike most here, I have never actually owned a jeep. I've spent some quality time in friends since childhood. Everything from old Willys on deer leases to more modern stuff on Colorado hunting trips. Always wanted one, but never really had a reason to get one.
Well I have come up with a reason now.
I have recently purchased a Class C RV that the family and I plan on using for the next 10-15 years. Mostly for trips out west, sightseeing and hunting. I would like to flat tow a jeep behind the RV on these trips and I think a scrambler would just fit the bill since I need to stay under 4,000lbs and need seating for 5. ( I have a 2 year old son and twin boys on the way. I know :crazy:)
Anyway, the weight restriction, flat tow ability, seating for 5, and the open air seating have left me with pretty much the scrambler as my only choice.
Craner8's below is what I have in mind.
I'll be lurking around as I read up and hunt for the one.
If anybody has any suggestions or advise please share.
Thanks,
CopeDog
WELCOME! Great idea and you'll get lots of thumbs up as you're tooling along if you do go this route :D
The ideal setup would be to track down one of the discontinued Warn full floater kits for the rear axle that would allow you to just unlock all four hubs for towing so you don't need to deal with dis/reconnecting the rear driveshaft, but they're pretty hard to find.
Otherwise, sounds like a sweet setup. I'm working on a shuttle bus-to camper conversion to pull my junk :thumbsup:
http://www.jeepfan.com/products/drvsus/warn-fullfloat.htm
What he said.
You absolutely don't want to flat-tow more than a few miles at at time with a Dana 300 rear driveshaft attached due to lack of lubrication. You could also look at swapping in another transfer case that is more flat-tow friendly, or go to a different full-float rear axle with aftermarket selectable hub options.
Jeep
Welcome to another TX'n.
Buy the best one you can find, money way ahead.
CJ's are cheaper than ATV's !
Welcome and you'll like the two bench seats. We get alot of use out of it. Very easy to do, really. Buy a good clean one to start with and build it the way you and your family like it. And this is a great site to follow.
Wecome! Being you're from TX you are already ahead of the game. Not only do there seem to be a bunch of Scramblers in TX running around on all those ranches and hunting grounds but most of them are pretty rust free! Good luck and post up any questions you have!
WELCOME! Echo the TX thing. I see fairly rust free ones advertised frequently. There are probably some hiding around some ranches in Texas somewhere. :drool:
I have an 85 with a Warn full floater rear that some PO used to tow behind a motor home. If I cannot merge the axle I found on an old CJ-7 that I think has a Gleason Torsen limited slip (at least I hope it does- the front has one! :woot:), I may be will to sell my floater whole axle. But that will be awhile down the road. I expect I will get a few posts asking to sell it tomorrow. When I first posted that my "new" Scrambler had on I got pinged righjt away by a couple people asking if I wanted to sell the axle. answer maybe!. The stamp says it has 2.73 gearing but I have not cracked it yet to verify. The Scrambler has the 4.0L head on the 258 so it ROCKS!. The way this things scoots, a PO might have changed the gearing in it. Anyway for the right amount of $$$ I also might be willing to sell it. It does have some rust but not as bad as a couple others I bought for parts. Again welcome & this is a nice place to graze for information. I have had several Jeeps but always something to learn or a super mod that someone has done.
I post a couple pics of Scrambler and a couple of the Warn rear hub outside & one showing inside :cheers:
Thanks for the warm reception.
I'll have to wait until I actually get a scrambler, then decide how to overcome the Dana 300 towing issue. Its good to have several options including clocking and the hubs. My choice will depend on what other things I need to do to get it going reliably.
I have searched and read the posts I can find on curb weights, but maybe someone has a specific answer for me. I plan on get a pretty stock jeep (I6, full doors, not much lift, normalish tires), add the two bench seats in back, and probably get a full coverage soft top. Do you think this setup will come in under 4,000 lbs????
Also, has anyone had experience towing one with a soft top like a tigertop? I am curious what the wind coming off the RV will do the watertightness of the top.
Again, thanks for the welcome and thanks to all the veterans.
Copdog
I would think the soft top behind an RV would be an invitation for trouble. These are not nearly as precision fit nor as secure as the modern tops and I would think that the constant buffeting would be problematic. No first hand experience other than having a soft top on mine as I pass tractor trailers on the highway.
Welcome from central TX! Enjoy the hunt for your 8!
