Jeremy
Scrambler Fanatic
- Carlisle
- PA
Well last night my 1946 electrical system gave up the ghost. The starter died and burned up a good portion of the wiring connected to it.
SO needing something to drive to work tonight I went out to my BLue 1981 cj8 fired it up moved 4 feet and throw a rod! Its still runs (baddly) but there is a hole the size of my fist in the dirves side of my engine block right near number three piston. SO I need an engine now instead of a rebuild. My 1982 is still in at the welding shop for rear body mounts but I finally got all that smog garbage back on so I expect that it will pass a visual inspection soon. If I had any doubt about buying a unlimited Its gone now. It was a long walk home last night after the flatfender left me sit. No to mention the letter of repremand I am sure to get for not showing up to work even though I called in that I was not going to make it. Talk about your bad days. Rant over.
