- West Bend
- WI
Yes, I used the stock sender. Zero problems. I used 5/16" line for the feed and the return. It then necks down to 1/4" right at the sender. I called Walbro directly and it was them that actually recommended this to me.I agree. Just thought it was worth mentioning. I also used a Walbro GSL392 (255lph) on the frame rail. Did you use the stock sender? Just wondering if you have had any issues with the 1/4” return not returning enough fuel and potentially causing to much fuel pressure at the rails? Thanks and sorry OP for the high jack.
