Good advice so far, I always suggest a good hard assessment of intended use, it will change alot, but atleast you get started down a path rather than just pinging around. I see you are in CO, where abouts? I'm in NM, north, and get into CO alot with family along the front range and property near Saguache. CJATE and I try to wheel CO together a good portion of July (he has a month to spend up from LA whereas I still have a &*^%$$ job), sometimes IBScramblin joins us and, of course, several board members are scattered around the state.
I would say this, if you are thinking maybe 35s, go ahead and go 35s, it is a bigger step from 33s to 35s, IMHO, than you would expect, it sure was in the case of my CJ5, my scrambler was built intending to run 35s and I still messed up alittle. I really like the notion posted above to do the gears first, then the suspension and tires, you won't get the visual effect but it'll be more fun to drive. Of course the safety stuff as Eric points out is paramount. If you have the $$ then do both. Figure out the ratio you want but keep in mind the power train you envision as you do yuour planning, if you plan a 4.0L AW4 swap go deeper than if you want a 258/T18 set up with a 4.0:1 Low range. Do you plan to drive to the trails or trailer? that sort of thing.
Lots to think about, zillions to spend, great fun to be had
tr
