Orionn
Vehicular Packrat
- Ann Arbor/Ypsilanti
- Mi
Just posting a few pics of my Scrambler. A few have asked about it so here it is:
Since these pics were taken, I removed the diamond plate one of the previous owners had installed under the windhield frame (only to find perfect sheetmetal).
Well mostly perfect, Its full of holes drilled in it for pop rivets
And whats worse, there were NO windshield Hinges!!
the WS frame was held on with Pop-rivets and Aluminum Diamond plate!!
(Yes thats Steel Diamond plate fully welded on the rockers and rear corners, Its strange, there is NO RUST/Damage on those panels he covered up. The guy had a thing for Diamond plate it seems)
The only real rust is just below the upper hinge on both of the 'A' pillars. I am looking for a good way to repair that. Does anyone know if then make repair panels for the sheetmetal below the upper hinge?
Its now sporting hard doors, and a properly fitted soft-top, 35" MTr's and Jeep Turbine rims.
Took me most of the summer to sort out the wiring on it and get it drivable, but I expected it to take time.
Not too long ago it was a basket case, so I am going thrue it and fixing the 'Shortcuts' the builder did
It takes alot of time to make thing right.
I'll post up more pics as soon as I can get a few current ones.
the WS frame was held on with Pop-rivets and Aluminum Diamond plate!!(Yes thats Steel Diamond plate fully welded on the rockers and rear corners, Its strange, there is NO RUST/Damage on those panels he covered up. The guy had a thing for Diamond plate it seems)
