Laser Cut Rear Crossmember install on our Washington Scrambler
CHIEFWAHO
Former SOA VP
SOA Board Member
Thayer
KS
Started out just to change body mounts and replace rear bumper. But you all know how that goes. The previous owner had caught something on the next to last body mount and ripped half of it from the frame, mangled rear cross member and bumper.
Just so happens I have been working on a reproduction laser cut (10 gauge) rear cross member and mounting tabs. I had a couple prototypes cut awhile back. I sold one to a CJ7 owner so I can make sure fit up of the fuel tank bolts are correct and the other one has been waiting to go on a Scrambler. I decided to use the mounting tabs instead of welding it to the frame. The mounting tabs use factory holes, so no drilling, just position the cross member on the frame, tack the mounting tabs to the cross member on the inside and outside of frame. Then removed it to fully weld tabs to cross member, paint and reinstall.
This is the cleanest frame I have ever worked with; there is no debris inside the frame just dust, WOW! All but the very front body mount came out like they were put in yesterday.
removed damaged rear cross memember
all cleaned up ready for new
fit-up of new
Looks great Jason...how much thicker is yours then original..
Truck
Jason,
You and your rust-free Scrambler(s) suck.
Signed,
Jealous in Salty Michigan ;)
P.S. - New crossmember looks good!
Let me know about one of those cross members.
I have a frame that is mostly repaired and could use one. I was thinking about a 4"x3" tube bumper, but yours might be quicker.
Carl
Truck
Stock thickness is .095" the laser cut are .1345" Does not sound like much but it is considerably thicker.
Carl
Not sure when I will have more available.
I had only (2) prototypes cut and am waiting for feedback from an install on a CJ7
before I proceed with having a bunch of them cut.
Want make sure the holes are correct for the fuel tank on the CJ7.
The next batch I may bump them from 10 ga (.1345") to 3/16" (.1875) thickness.
