https://www.beugler.com/There is a pin stripping tool that has a wheel. You can put a magnetic strip for a guide and roll a straight line. Or in your case , make something to hold the tool against the wheel and rotate it.
Which alternator are you using? My original is the ugliest thing in my engine bay right now!Success proved. I got the belt tensioner spaced out and mounted up, got a new alternator, and installed the belt. Looks perfect. Pics show the clearances. This is the most compact front drive possible using the truck brackets. View attachment 93999View attachment 94000View attachment 94001
I used to have one of those- my hands were never steady enough to use it…
It’s a stock Deco alternator for a 2004 Silverado 145 amp. Got it at OReillys with a lifetime warranty. It’s a rebuild but looks great. If that’s not enough I’ll upgrade to a Powermaster 250.Which alternator are you using? My original is the ugliest thing in my engine bay right now!
Here’s my home brew tight radius manual bender.
The lines are the NiCop nickel-copper lines. They are so easy to bend and flare. And I’m digging the reddish tinge to the lines- goes with the paint.I’m using a Mastercool kit - hydraulic flare tool. It’s amazing. Makes perfect flares, plus does fuel line quick connects and 37* AN fittings. I’m just borrowing it but thinking of buying one. The Eastwood tool looks great but the Mastercool has one advantage- you can use it anywhere. Doesn’t need to be mounted.What flaring tool are you using? I used to hate brake line work. Until a buddy purchased the Eastwood flaring tool. Love that thing, makes it enjoyable.
What was your source?Also, the brake line armor shield finally arrived, so I can get my brake lines done.
I got both the NiCopp and the shield off Amazon. The line came from Inline Tube, the shield from The Stop Shop. Inline Tube was the only place that had .028 wall, other places were thinner. I got the armor from The Stop Shop after FedEx lost my order from In-line tube and they raised the price and wanted me to reorder instead of reshipping. I think they have also raised the price on the tubing but it was excellent quality.What was your source?
Also planning on the NiCop brake lines.![]()
Thanks RandyI got both the NiCopp and the shield off Amazon. The line came from Inline Tube, the shield from The Stop Shop. Inline Tube was the only place that had .028 wall, other places were thinner. I got the armor from The Stop Shop after FedEx lost my order from In-line tube and they raised the price and wanted me to reorder instead of reshipping. I think they have also raised the price on the tubing but it was excellent quality.
Supposedly Napa can order both but Amazon was quick and easy.
A milestone, and thank goodness that’s done. Yes, brake lines are finished. The NiCopp is amazingly easy to work with, I don’t think I’ll ever use anything else. And the Mastercool flaring tool made every flare perfect the first time! Here’s the pics. I think they came out fantastic- the front 2 lines follow the contour of the inner fender and everything’s secured in rubber lined stainless clamps
Thank you!Randy- This is seriously impressive work you’ve done here. I don’t want to join the hoards of crazy boaters on the water this weekend, so I’m going to spend some time catching up on your thread. Amazing!
