- Easton
- CT
So, I mentioned in another post what I had done, but here is a bit more.
From the PO, I had an MTS 20 gal poly tank, which uses spacers to hang it down about 4" to fit the extra capacity with the 15-gal skid. I always had some issues with it.
1) as MTS said, it does not fit - my '86 CJ D44 with OX Locker diff cover defiantly hit. More than once.
2) Even though I had replaced the filler and main vent hoses, I could not fill the tank unless I cut the flow to about 1/2. This was annoying
3) then, I could not fill to the "stop," if I did, gas would leak out of the filler, despite a new cap and a clean and smooth surface on the filler neck.
4) the damn evap/liquid check valve/rollover check valve would also leak if the tank was full and I went up hill. - basically, I could always smell gas a little bit.
5) the outlets for # 4 above appeared to let loose while I was at the Killington Jeep Jamboree this summer. Filled it up and tons of gas poured out of that area on the top of the tank. took me a while to figure out what was going on. I had another day of wheeling left, so I was a little nervous, but I let the tank run down and filled it even less.
6) aside from hitting the diff, the tank and skid was just too damn low being spaced down.
This freshie is from the National Scramble:
So, I bought an ebay tank and cleaned it out, but honestly, it was really clean in there. The outside took some scrubbing, though
out with the old - brackets still on in this pic, but removed, of course.
tank is ready. Sender and rollover valves from MTS (strap and filler hoses too - not shown) and 1/4" line from NAPA.
good riddance to bad rubbish - kinda looks like a squid, though
GenRight Crawler skid, and done (with a few new bolts - a few met with a spark-filled hot death)
I run a 4.0, and the fuel pump was mounted to the drop bracket, so I had to relocate it. I replaced it, and the first pump screamed something fierce, so I got a different one. I made a 1/4 thick steel mount and bolted it in between the frame and the bumpstop on the pass side - but that hot mess is a story for another day.
Now she runs great, NO smell of gas or leaks. I can fill the tank like a regular person and fill it full.
Worth it.
Worth it.
