Mirror mounted Spot Lights
Going Postal
Corvallis
OR
Anyone out there using mirror mounted lights? Just thinking about mounting a set of spot lights I have for hwy use. I have a big set of 6" Hella floods that work great for seeing the sholder of the road. I'd like a set for seeing further down the hwy. I want to see that moose long before he jumps out in fron of me.
I'm wondering if lights mounted on the review mirror brackets will have alot of glare off the hood...
Not personally, but that's one of the two acceptable places to mount them IMHO. Either there or on the bumper.
I'm not a fan of light bars at all.
I wouldn't think that kind of beam would be a real problem on the hood...
I've got a set there, but since we can't run them on roads in MD I haven't used them yet (as a matter of fact, they're new enought that I test mounted them and still have to go back and wire them to power), so I can't answer the glare question. I have seen guards that fit under the lights (KC, I think) that would help if it's a problem.
Just last night was checking some other sites and saw a cool setup, a bracket that fit on the grill bars that held two lights. Could be moved anywhere from just over the bumper all the way up to the hood. If I was going to use a set for driving a lot I think that's how I'd go. Wasn't even too expensive, but should be easy to make your own brackets, too. Was on www.jeeps.com if you want to check it out.
