- West Bend
- WI
I put the axle up on jack stands and got right to it. First I pulled the cover to let it drain out. Then onward to the axles. First removed the 4 bolts that hold them in.
After I got those out I flipped the brake drum around and put the lug nuts back on 3 complete turns and used it as a slide hammer. They both popped out with a few smacks on each side.
In order to get the pinion nut off I used a pipe wrench and a breaker bar with a pipe on it. Yup, I'm sure that's considered naughty but I don't have a working air compressor out there right now for my impact gun.
