My new "old" cj8!
roamin12
honolulu
hi
Howzit everyone! I used to have an 84 when I lived in NJ. I swaped in an AMC 360 and did "some" work to it but really not much due to lack of funds. I absolutely loved it though. What's not to love about the Scrambler!
I recently picked one up here in Hawaii. It needs alot of work and I'm no expert but I'm building it to the best of my ability and I'll learn along the way. It's an 81 Scrambler with 8 inches of lift; all suspension, and brand new 37-12.50 Wrangler MTR's. It has new rotors and Mile Marker hubs along with all new spindle bearings. The motor is the original 258 inline 6 with new everything from Clifford Performance; including a rebuilt head, 4 barrel aluminum intake with a Holley 4 barrel carb, and dual output headers that leads to a custom bent dual exhaust with Flowmaster mufflers. There's also a pair of KC Dailighters up front and a Centerforce Stage 2 clutch assembly. I recently ordered new replacement panels; rockers for both sides, a cowl plate, and a fiberglass windshield frame. I picked up a roll cage from a YJ for $100 that I hope will fit; although it won't quite be a "full" cage, and an Acme full hard top for another $100. I also ordered 4.88's to replace the 3.73's. I actually just put 33's on there because those tires do not turn going over the mountains with those 37's and I don't know how to change the gearing. A quick question....Will it be overkill with the 4.88's and 35's? I'm wondering if the gas mileage will be better with 4.56's? It's on road more than off....
Well there's a bit about what I'm doing or will be soon. (I just severed my ulnar nerve, tendons and cracked my bone at the elbow so it'll be a while for that to heal) I'm going to do what I can to keep it moving forward.
Thanks for welcoming me on here!!!:cheers:
Nice lookin' rig. Congrats! :cheers:
I'm no expert either, so I'll let others answer your questions . . . hope you heal up quickly! I think turning a wrench would be good physical therapy.
Nice! :thumbsup:
I can sypathize with your ulner nerve injury. I recently had surgery to move the ulner nerve in my left elbow. I had a lot of compression and 2 fingers had gone numb. I have feeling in my fingers again, but my elbow itches and stings a lot and I can't rest my weight on it. Good luck with it.
Welcome! looks like a great place to start. I'm going to go with 4.56 with my 35", although I have a V8 and an OD transmission. I think with the 6cyl, 4.88's would feel nice.
Alot depends on the condtion of the engine and what trans you have.
If the engine is in good condtion, then the performanc mods will help the overall feel and drivability, if the engine is tired, the perfomance mods are just bringing back close to a stock engine.
What transmision do you have?
Alot will depend on weather its an 5spd OD trans or not.
If you have a T-5, and use 4.88 gears, you will recover a bit mileage when using OD (5th), but will need to downshift on hills/mtns.
Its going to be alot like driving a 3-spd with 4.56 gears for fuel economy and power (in other words, not great).
Gearing:
4.56 gears correct for 35" tires, it will feel close to a 'stock' jeep.
4.88 gears are lower than needed, but will get you power (crawl ratio/seat of the pants feel)at the expense of gas mileage/top end speed
4.10 gears will get you better milegae, at the expense of power (with the 6cyl, a V8 not so much)
On mine, I am building 4.10 gears with 35" tires. But I am also running a SBC 350, and early NV4500 transmision to make up for the milder axle gears.
My goal is drivabilty on the highway (70mph) and fuel economy using 5th gear (0.72:1).
The transmision comes into play offroad for my lower crawl ratio with the 6.32:1 first gear.
Sorry if that sounds confusing.
hope it helps some.
Welcome and congratulations on your purchase. I have no answers for you on your questions but would be interested on what the cowl plate you ordered looks like and how it was to install. I am in the process of building my 83 and the indentions on the side of the cowl plate are rusted and I was thinking about ordering on myself. None of the ones I have seen show a side view and that is what I am most interested in as the rest of the cowl is in good shape. So...keep us posted on your progress and enjoy what I am sure is great jeepin' weather.
Welcome and congrats! Looks like a great start to a project :thumbsup:
I did 4.56 gears with 35s knowing that I was going to do a 4.0/AW4 swap that got me OD. Agree that 4.88s sound right with the stock 258.
Nice intro post and look forward to watching what you do with it :wave: :popcorn:
You got a full hard top for $100???? Welcome. I hate you already. ;-p
Thanks Motojosh. I agree...if i could only grip a wrench.:(
I feel you Robert! They're telling me I have a 2yr recovery time and I "may" get full use of my hand back. :banghead: What's your prognosis?
Thanks Randy. I was thinkin 4.56 might work. Hopefully I won't guzzle with the 4.88's!
Orionn...Thanks for the details!:cheers: but I am a bit, a bit, confused.:confused: I currently have, I was told by the guy I bought the Jeep from, 3.73's. I just put 33's on there? How's that for a temporary fix? The Jeep has a Borg-Warner T-5 trans. (I miss my T-176 that was in my old Scrambler but with the AMC 360 my milage seemed horrible!) The engine is probably pretty tired but I honestly have no idea. I'm thinking about waiting on the axles and trying to get dana 44's and build them instead? I have a one piece axle in the AMC 20 and was told that's just about as strong as a 44 so I don't really know which way to go. It's sounding like no matter what 4.56 is this best route because she'll be on road much more than off. From what you wrote, I think I'm looking to go the way you are with yours.
aac1431..I haven't put the panels on so I will post some pics for you. They're Omix Ada. The first four are the cowl plate. The last pic is of the rocker panel....
Thanks Big Walton. I'm afraid to jump in with the 4.88's. Especially with gas close to $4 a gallon!:crazy:
AK-RWC.....LMAO That's part of the advantage/disadvantage of living here. Hardtops, especially the Scrambler...= cheap. (Noone wants a full hardtop in HI! lol Just my crazy ***....but other stuff though can be difficult to find unlike the mainland.:(
Jims Chop Shop....thanks man. That may be what I end up with.
Well I think I responded to everyone! Sorry if I forgot anyone and THANKS for reading and responding to my intro. Seems like a good group of guys. I appreciate the help and hope I don't annoy you all with all of questions to come:D!
