My turn!
Definitely keep the body around until you are done. There is sure to Bo something to measure or some part you forgot to take off (like the windshield washer nozzle that you can't buy anymore).
Yeah, I'm going to keep it. It's on a wooden dolly I had to make...pics coming shortly, and you're not going to like it :rotfl:
The original idea of tilting the entire body onto the tailgate area worked until I measured the length of the tub then measured the floor to ceiling space. oops :rotfl:
Had to use a cut-off wheel and went right behind where the seats are. I have no idea where I'm going to put this stuff, I may end up getting a storage garage.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
There's some sort of cylinder mounted to the inside of the tub, behind the read driver side fender. Anyone recognize this?
attachment.php
attachment.php
The cylinder is the rollover check valve for the 15 gallon tank.
Alright, that'll be on the list for replacement then.
I cheated and used a cut-off wheel to remove the u-bolts. Didn't feel like killing my knees trying to unbolt those things. Snapped right off, giving me multiple heart attacks :rotfl: Same with the drivers side rear hub. Heat with acetylne, use the puller...heat...pull....heat....pull....heaaaat.....WANG hub goes flying across the room :rotfl:
I'm not seeing what looks like a 2 piece axle, so maybe those have been replaced. I haven't taken a close look at the axles yet, or whats inside the housing, so I'm speaking from my butt right now.
If you had to pull the rear hub off of the rear axle then you have the two piece axle.
OK. Once again, proving I'm the master at confusing myself. For some reason I was under the impression that the 2 piece deal happened within the axle tube, some sort of disconnect, but that's for the newer style systems with automatic locking hubs, isn't it? Like in the XJ's up front?
Two piece rear axles have a single shaft from the diff to the end of the tube and then are splined and threaded at the wheel end. They pressed on the hub and put a big nut on to keep it all together. Once you've pulled the hub off the shaft, trash the whole thing, you'll almost certainly have a spun hub in no time otherwise if you try to reassemble it.
http://image.4wheeloffroad.com/f/35...131_9809_rear_axle_swap_tips+amc_model_20.jpg
You're thinking of the vaccum disconnect garbage they used on the front axles to decouple the wheels without locking hubs.
Yeah, the vacuum thing, that's what I got mixed up in my head. I've got Moser 1 pieces on the list.
Of course, if it turns out the frame is beyond repair, then it may be a moot point...
Got the front axle housing out completely, with the springs and steering box. Pile of old parts just keeps growing and growing! Still worried about the frame. The back half is in VERY bad shape. My father says he's repaired worse though, so we'll see what happens. Once I get everything off (pretty much only thing left is the rear springs and axles) I can get it flipped over and see what there is to see.
Current plan now: once it's done being stripped down, it's going to get either sandblasted or dipped...probably dipped. After that comes lots of cutting and welding. You can see the shower of rust and metal bits that have fallen off of and out of the frame as I've been hammering on it. Some of it has even been pried out with a screwdriver.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
yay more pictures. Had to use a small block chevy head to keep the frame from flipping up once the front axle came off :rotfl:
attachment.php
attachment.php
