Need!!!!!
Major Jack
Zillah
Wa
Does anyone have a trashed AMC 20 or 35 rear housing they would be willing to cut up? I would like to have a flange with 6 to 8 inches of tube.
Sorry I can't help, Captain....
My front and rear set were laying in my scrap pile and about to go to the scrap yard....then a fella contacted me that wanted them badly, and I gave them both to him for 5-cases of Miller Lite :woot:
Otherwise, I wold have gladly helped you out before taking them to the scrap place.....sorry!
I have a narrow track AMC 20 out behind my shop. It is burried in the snow right now. If I can figure out how to get it out I could probably get the flange to you, but it may take a while. I hurt my back a couple of weeks ago and I can't do any heavy lifting right now. How soon do you need it?
Take care of the back. 15 years ago I had a "Strained" back, so the doctor said. Three weeks later I a paralized from the waist down. Thankfully, surgery corrected.
Get to it as your back will allow. I will look forward to hearing from you.
I am talking with a machine shop teacher about modifying a set of spindles to fit the AMC 20 for a floating rear. For his situation, he doesn't want a whole housing laying around in the shop.
full floater amc 20 rear disk project
hi saw that you are doing a amc full floater on a amc 20,,,,, so here are a few photos of the full floater disk brake project i am almost finished with,,,,, as far as the mach work on the spindles,,,,, i used early chevy small bearing units,,,, and had the dia on the back side,,, part end going into the amc 20 flange cut down to make a tight fit,,,,, had a little drilling to do to get the hole location to match up ,,,,, take a look and if i can be of help just let me know,,,, i have everything i need recorded with lots of photos goood luck
Captain- keep us posted on what you're doing. I'm really interested in making my 20 a full floater, just concerned about axle shaft diameter to fit through the spindle.
I'll keep you posted Randy.
I have decided to not get excited and just go crazy buying parts.
I have decided to take my time and look for deals. Want to see how CHEAP someone can make this happen.
1st. items bought - Spindles $55.00 including freight off E-bay and in Washington State.
Now, gonna look for calipers & hubs.
Since I am in Alaska, it's more of a challenge. The city doesn't allow wrecking yards in Juneau.
The one thing I am gonna have to spend some time figuring out is the axles. Got a wide trac rear. So, I'm not sure if using the Dana 30 long inner axle and cutting splines in one end will work.
Now that I have the spindle, I could use the end off a 20 housing.
I have a D35... just remembered. I'll pull it out of the scrap and cut off the ends tomorrow. It's out of a 2000 XJ. Will that work?
Well, I pulled it out of the dumpster- It's a c-clip style which I think is different than the non-c-clip 35/ AMC 20 style. Let me know before I cut it up. On mine the bearings are seated in the axle, and the seal driven in afterwards...
