Got the tailgate installed then moved onto the windshield hinges. Only mounted the bottom portion till got the air vent and the hood mounted. Installed the hood and ran into problems with the pass fender not aligning right with the grill. On the pass side the lip of the hood was even with the grill and if you were to look closely you would see the grill was a little forward of where it should be with the fender. Ended up drilling new holes in the fender to allow the grill back about 3/8". Really getting sick of these half a** chinese after market body parts. After getting that aligned I still need to move the grill just under 3/8" toward the drivers fender. You can see the gap on that side. I've already loosened the bolt for the grill mount and pulled toward the drivers side. Probably will end up cutting the body bushings to allow the bolt to slide toward the drivers about that amount. I should have checked the hood before I did the final paint.
keep up the great job!!!!
