New Guy Here!! History and Auto Trans vs Stick ??
Fullmag
FULLMAG
Palacios
tx
The History
I have lurked for about eight years. I own two scramblers. One was running when I parked it. It is an 82 with 1/2 cab and underdash a/c unit. The other is a 79 narrow track. I have no title for it. I bought it for the tub. It needs some small panel work. The bed has a corner near the rear wheel that held water from a flat tire leaning the jeep. The narrow track has a bumper welded to the front frame. My plan is to use the 82 frame and tub from the 79. I would buy new sheet metal for the 82 and reuse everything left over for the 79 narrow track. This would be a around the farm or lease jeep. Both of these are stick.
Years Later
Today I bought a 2wd 1998 XJ with a 4.0 and auto trans for $200. It has a great engine with 112,000 miles. It runs strong. I want to do the 4.0 swap. I also bought a NV3550 in 2003 from a rolled Rubicon with 800 miles. I have the bell housing clutch slave cylinder, CPS and parts. I like that the auto is hooked up already. But the NV3550 just needs to be attached. My fear is taking something apart that is running to change it up. I know you guys do this all the time. I do like the cool factor of the NV3550.
If I go with the stick I will asking for you help. After all this do I do auto or stick
Thanks
Welcome.
Scrambler first year of production was 1981.
As to your swap, sounds good. I'd call Novak and tell them what you have. They can tell you (or sell you) any little bits you might need to compleate the swap.
Good luck and please post pics.
I am sorry for the year. I was told it was a 79. Goes to show I have a lot to learn. I am going with the stick. I have a thick binder printed out from the old cjoffroad 4.0 swap section. Thanks for your advice
I did a 4.0 swap for skell22 last year and it was not that hard, just alot of wiring to follow to keep it OBDII. The stuff from cjoffroad really did not help me that much as if I recall it was mostly OBDI stuff and I found by the time I was done changing all the sensors and such and got the wiring from the correct jeep to make it OBDI, it was going to be easier to use the OBDII, plus you get the better diagnostics. I used the wiring and such from under the hood of the XJ and clipped the diagnostics port from under the dash and followed the schematic, outting the port under the hood. I had probably 40-50 hours in it, but that is because I could not find the schematics from a 1996 because of the uniqueness of that year (old body style, OBDII, etc) I had to use 1995 and 1997 together to make mine work....great lakes XJ site has all the wiring schematics if I recall correctly. The best part of it was when it wouldnt start, I was able to hook it up to a snap on Modis and find out that my brand new CPS was bad...that would have taken me forever to figure out because who would think that a new CPS was bad. Take your time and follow the schematics and you should have no problems doing the swap. The motor mounts are the same, you will need to adapt the clutch slave, and you will need a clocking ring to mount your Dana 300. When you do the clocking ring, you might need the extended tranny to transfer case seal to ensure that you will not leak...I think teraflex makes it. Good luck, and if you have any questions, feel free to ask....But PMing me is the best course.
Welcome! Sounds like a good project. The 3550 is a great transmission. A Hurst or B&M short throw shifter really makes them shift nice.
