New Scrambler Owner
Cjp07
New member
Lowell
MA
Just posting to ask a couple questions. Bought my first Scrambler several months ago. Has some interesting features. Rear hubs, front bumper with multiple receivers, and full rhino lining inside and out. The diamond plate is not hiding rust, which is almost nil on this Jeep. Could anyone answer why? 1. Rear hubs 2. Why this bumper 3. Why the dual transfer shifter, which I’m guessing is aftermarket and 4. If anyone knows anything about this Jeep I would be curious...prior owner didn’t seem to have a lot of history.
Thank you.
Rear hubs are a Warn kit that is out of production. They are sought after and valuable.
The stock hubs on the AMC20 is a known weak point. The conversion to locking hubs is stronger.
You can also flat tow it by setting all 4 hubs to free wheel and not worry about the transfer case buying up.
Transfer case dual shifter allows front low rear neutral for “digs”. It also shifts slightly easier since you are only shifting one rail at a time.
Front bumper is custom, I bet the previous owner had a custom from seat rack for bird hunting or similar.
Welcome, nice 8 you got there.
Thank you both. So much good information... So I found a later roll bar to add shoulder harness and roll bar mounted spare. My nephew made new wood rails out of oak almost to spec. Want to remove the diamond plate and put the decal stripe and letters....it’s a 2.5, ran like crap..new weber made all the difference. I don’t mind the 2.5 for what I do with it...that’s all so far..
My guess is that front bumper was built for easily removable flat towing setup (almost a dead giveaway combined with the rear dialout hubs) and possibly a removable winch.
Sounds likes a good plan, post your progress as you go along.
Welcome! That’s a great place to start. Like your plans!
Removed the old original rollbar for a later model rollbar with shoulder harness provision, spare tire mount, and wood rail mount. A friend did the bodywork for next to nothing. Was a little tricky matching the factory color with the current old paint..but came out good enough. Only one of the torx had to be cut. I'll replace witht the proper Black-Oxide Alloy Steel Button Head Torx Screws 3/8"-16 Thread, 1-1/4" Long (hope thats correct). Strange that water had pooled under the rear driver side bar between the bar and the deck. Quite a bit of water.
