New to the site.. my build plan
overland yj
bristol
pa
hey guys.. I just figured id introduce myself. My names Gary and i am planning on building my scrambler with my dad. He got me into the whole jeep thing.He is a member here as well. I currently have a rust free 94 yj. I love it but i would really like a little more space to pack gear. We are into overlanding and camping all over the country. Ever since i was young my dad and his best friend always talked about the cj-8 so thats where my love for the scrambler came from. Last year my uncle bought his cj-8 and that just kicked me into gear! My scrambler will be a bit different. Since i have a clean yj i want to use as much parts as i can from wrangler to build the scrambler. While i love the origional, and with the parts i already have i have decided on building a 87 scrambler if they would have made them. I have seen pics of the yj scramblers overseas and thats what i am aiming for. I plan on getting a new tub and have tdk make me a frame. It will have a yj interior, front clip, and yj flaires. My yj had an optional "splash" graphic and i decided i am going to put that same graphic on the yj-8. I have matching full and half hard doors for it. It will have my yj drivetrain from the 4.0 and 5 spd to the np231 and a 8.8 rear and a dana 30 front 4.10 gears on 32's with my 3.5 bds lift. I would like a half hard top and tonnau cover for around town and a full hard top for the trips. I Just sold my bike so i can start getting what i need to do the swap. Hope to start it this summer. I will be posting a build thread when i start.
Take care guys and heres a pic of the yj
Welcome Gary... sounds like a plan for fun.
Having swapped a 94 YJ motor into the Scrambler I own, I've speculated that if you swapped the Wrangler front clip (fenders, hood, grille), drivetrain, and the YJ dash/interior, you could simply use the entire YJ harness for everything except the fuel tank (don't think the YJ tank will fit, plus the filler's on the wrong side)... which would make for (a) a relatively easy swap and (b) upgraded electrics throughout.. you'd just lose the "CJ"ness without the old school dash and the rounded front clip.
You'd be able to use the YJ radiator, A/C condensor, coolant bottle, washer bottle, etc as well as the YJ engine compartment is slightly wider.
I'd do one of the conversion grilles they're making to get round headlights, but otherwise I'll be :popcorn:
Welcome!
I just had a horrable flash back to my last jeep with those square lights Burrrrrrrr. Actually it was the only thing I hated about the jeep. 6cyl, 5 speed the thing was quick and got reasonably good mileage. Ya know I have very fond memories of all my past jeeps
I loved my YJ. Not as much as my XJ, but that was my first vehicle and has a special spot in my heart. The only thing I did not like about my YJ was the 4 cyl engine. But the Jeep was super reliable. Had it for three years and put a lot less money into than I already have in less than 1.5 with the CJ. Oh well. Love the Scrambler too.
yea i hear ya guys.... i love the traditional scrambler, dont get me wrong. Thanks for the info i may have a few questions for ya when i start the build. This is my first jeep and it is special to me and i could never think of selling it, but i really want a scrambler... instead of having two jeeps (at this moment of my life) i figure i still have the base of my yj and get enough of the scrambler feel to hold me over... for now! I knew i would get my balls broke a little about the square headlights and all ha But hey im building what i want, something that will suit me great on my expeditions, and something different.. and to say that if jeep kept building the scrambler this is probily what it would have been.
If you're having TDK make you a frame, have them build it to accomodate a YJ gas tank. If you go with an Aqualu or fiberglass tub, you can put the fillers on the YJ side (or obviously cut and patch to move the filler to the YJ side of a steel tub). Your wiring harness will work throughout so long as you keep the YJ dash.
What you're doing is similar to how my build started, until mine got out of control and I ended up building a nearly new Jeep. I started with a CJ-7 (where I had previously done a YJ tub conversion) that had a broken frame and planned on putting everything into a TDK frame with an Aqualu tub. Then I decided to do SOA, use OME YJ springs, new sheetmetal, new upholstery, dual batteries, auxilliary fuel tank, . . . .
yea i am going with the yj dash. I am not sure i want to cut and patch so id prob just end up with a cj tank. I figured i would make my move on a tub first so i know what i will need when it comes to the frame. Im pretty positive im going to have tdk make me one. I believe i read the yj axles are about 10" wider than the cj's. So i am going to haveto play with the back spacing on the rims to keep the tires where i want them to sit. Does anyone know what people are doing to fit yj axles under a cj?
YJ axles aren't that much wider than wide-track CJ axles. Either way, just have TDK bend your front frame rails to accomodate the YJ front end. Jeremy Pulse, the owner, is super-easy to work with and he has all these dimensions on-hand. The forward crossmember will be slightly different too. Seriously, if you call him and say "I need a hybrid CJ-8/YJ frame so I can pair my YJ axles and front clip with a CJ-8 body," he'll build it that way.
Have TDK build the frame !!
That way every thing you have fits !!
Steering box and linkage,axles leaf springs , sway bar
Would make your life easier !!
Good luck , can't wait to see you finish it
Maybe a full roll cage designed to look like the yj family roll bar !!
What is your budget for this build ? I am thinking the frame and tub will run you $6000-$7000 ???
I love the 2 dr unlimitted look. They yare a little pricey.. i figured i can build my yj into a scrambler for cheaper then that.
i just sold my bike to get this thing going. My dad found a guy parting with his project. He had a tdk frame made and has a new tub. Too bad his build plan was to build a crawler as he had the frame bobbed. He was asking 3500 for the tub with the cj front clip including two new fenders that i would probily just store for a later date. Im thinking on throwing him an offer. Next i would put an order in for my frame. I have about 5 put away for this project now. I know i will be putting more $$ into this down the line as it comes time for paint and tops ect...
Welcome Gary, I know exactly what your after.
This: The exported long Wrangler.
IF you were only using the engine/transmission/and front clip from your YJ, I would say your good to go using a current CJ-8 as your foundation. But since your wanting to use the dash/windshield,t case, lift and axles, you will run into too many problems reto fitting that to a CJ based frame due to the rail spacing, bellypan configuration, and axle perches (mainly in the front).
What you need to do is have TDK make a YJ frame to CJ-8 length. This way ALL of your current YJ stuff will bolt right into the frame as the front and rear rails will be spaced wider apart. Axles and correct gas tank (for the injection pump) will bolt in. The Belly pan will fit for the t case holes, etc, etc.
I would NOT buy a new tub. You will be forking out a huge amount of cash only to get a CJ based tub that will need to be modified to fit your YJ dash, windshield, firewall routing, etc, etc. Instead, start with either your current YJ tub or find a good donor YJ tub and lengthen it to Scrambler specs. You can either buy the needed panels/rear floor sections OR do as this guy did and graft in your own:
You will be thousands of dollars ahead of buying a new CJ-8 tub. Then you can focus on the little stuff like longer fuel/brake lines, longer rear driveshaft, ebrake cables, top options and other little stuff people don't consider that all add up in time and money.
Myself, and many other here do a lot of fab and custom Jeep work and that is how I would approach this based on all the Scrambler and YJ stuff Ive worked with (and measured/compared)
That said, I do think they're ugly and to each their own. I would build a real 8 and call it done.
I'm going to guess no one knows the history of these - but I have a feeling they were made from leftover bits Chrysler had when they bought the Jeep line - Scrambler parts, world cab, and their new Wrangler grills, and in the supreme marketing strategy Chrysler was known for they thought no one in the states would want them so they exported them.
If I were the OP, I'd do one up like these ;)
