For $650, the owner doesn't know what a CJ-8 is worth OR it MIGHT (not guaranteed) to be worth $200-$650 for some parts (in that case, no CJ expertise is needed, you can added it up yourself).
I'll start off with some stuff to look for that goes beyond the obvious stuff of buying a 20+ year old vehicle.
HOWEVER, a lot has already been posted on this subject on various websites if you use the "search" feature on:
www.CJ-8.com,
www.cjoffroad.com,
http://www.jeepsunlimited.com/forums/forumdisplay.php?f=36
1) Rust especially common (besides the whole vehicle being common to rust
) on: floor boards, panel with embossed "Jeep" logo behind front wheel, rockers (behind rocker guard), frame by rear spring shackles (actually check around all shackles), wheel wheel lips, rear cross member at body mounts, windshield frame along/behind seal at bottom of glass and at hinges.
2) T176 four speed was the best manual tranny (medium duty) - easily identified if it has the orginal gear shift lever that is straight. The other T-4 (4 spd) and T-5 (5 spd) trannys (both light duty) came with bent/crooked gear shift levers.
3) 258 cu in (4.2L) I6 was better engine than I4.
4) 1983-1985's came with wide track axles that are slightly more stable.
5) If this is a 1986 CJ-8... buy it!!! That is the long sought after "Holy Grail" of CJ-8s that were supposedly built, but never seen. Some 1986 CJ-7s came with stronger Dana 44 rear axles (because they ran out of the AMC 20 axles).
That's just a start of some basic stuff unique to 80s CJs
