Recent progress...
For some reason, posts from my home computer aren't working. These are the things I've gotten done since last weekend:
pulled the stock front axle:
reinstalled the newly locked diff in the new housing:
swapped in the 6-bolt hubs:
changed the ball joints:
pulled the old u-joints:
started installing the new ujoints:
While pulling the rear driveshaft, I found a little issue:
I also found one of the old ball joints had a lot of play and one axle u-joint had red dust where the bearings used to be in two caps... I think I started in on this at JUST the right time!!!
I don't know if anyone else cares to read about this stuff, but it makes my progress seem so much more real to see it posted on here so I'm going to do it anyway
My neighbor said he should be able to do the rear gears later this week, so the next thing for me is to pull that rear axle and get it where he can work on it... with the long weekend this week, I have serious hopes of getting things well on their way to running shape and that will allow me to work on the steering in time for Oak Ridge!
Now I just need to come up with the socket thing that fits the split sleeve in the axle "C" for the knuckle reinstall...
