No Show For The Nationals
BOBCAT
Louisville
Ky
Well, it looks like I'm going to be a no show for the nationals this. Thanks to GOOD OLE MURPHY'S LAW, Everything that could go wrong has. Everything has been snowballing the last couple of days., mainly the motor swap. What I thought was going to be a swap, plug and play didn't work. I can't get the motor to fire up. No fire to the coil, what I mean by that is I lost voltage from computer to the coil, so in turn no voltage to the spark plugs. I've been f@!$%&*^%$ with it for the lsat 6 hours and can't figure it out. So I guess I'm not going to make it to Clayton.:mad: :mad: :mad: :angry: :angry: :angry: :shrug: :shrug: :shrug:
Make it anyway. We have a seat for you. And, if you bring the Scrambler I bet Thursday afternoon we can have it running for you too :D I am serious. Eitherway, don;t back out. We have you covered, seriously.
Dan
Go Don....Dan is right, I'm sure. You'll have a great base of knowledge there to get it running. So, step back, have a drink, relax a bit and it'll all come into perspective.:D
I've wired 4.2's, yj 4.0's, tj 4.0's, 350 tbi's, tpi's, and a couple of late model votecs, bring and we can chase it down! Best thing is to undo the engine side. Battery. Ignition. Ground. You are installing a 4.0?
Good deal. So it is settled then. We will see you in Clayton. Can;t wait to meet you.:p
Just Venting
I was so frustrated this afternoon, I was ready to quit. I've barrowed a scan tool this evening, to use first thing in the morning. What gets me about the whole thing is the motor ran great before the swap,(engine is out of my yellow scrambler) the only thing different is the engine crank position sensor, auto trans and standard trans take different sensors, so I think that the one I put in is bad. I've tried a couple of different parts places and they don't stock them and say they have to order it from the factory? Which will take several days to come in, but I'm still checking around, maybe a dealer will have it but I bet it will cost at least $150.00 from them, Advance auto
's price was $97 and some change. So if someone has one for a 92 wrangler 4.0L with a auto trans please let me know.
I think I'll still make it to Clayton, but I may be a day late and possibly without my scrambler still trying to figure out what to do.
Don
I will try to call some places here and see if I can find one. Maybe we can find out there and get it to Clayton.
come on Bobcat there will be enough jeep heads to get it going
as Dan said there will be a seat somewhere to ride if it doesn't get running
you'll miss all the fun!
everybody here says get your Scrambler here and they will try to help!
Just got off the phone with him. Sound slike he will be there one way or another. I called around here and could not find a CPS in stock. He has a line on one and should be in at 8:30 am tomorrow.
go go go don..!!
add to everyone else.. don.. you should go regardless.. load that thing up and you will get it running when you get there.
mike (scrangler) has experience w/ 4.0's as well and I'm sure he would be of help as well.
BTW.. what ECM are you running? and what wiring harness?
when I did mine, the ECM had to be a manual ECM for it to match my manual transmission/CPS. But, that partially was a result of the harness I used.
I haven't chimed in yet, but I hope you make it, Don!
I know he pulled a CPS off a 94 YJ auto that I had. It was a daily-driver until a co-worker ran the motor out of oil, so it's hard for me to believe it would be bad; it is possible, though.
Good luck getting it going, Don...I'm pulling for you!!!
Craig
The problem is that the wiring harness is out of a 92 wrangler and the cps it takes for and automatic was used only in 91 & 92 so no one stocks it. I check with 6 different jeep dealers in 3 different cities and no one stocked it. One dealer 50 miles away said they had one and I asked them to double check it and they said yes, so I drove 50 miles to pick it up and guess what, it was the wrong one (great parts man). A local Orileys ordered one for me and it's supposed to be in at 8:30 so I guess we'll see. Got my fingers crossed that it will take care of the problem.
Don
It's Finally Running
WEE DOGGIES! Finally got it runing. It's now loaded on the trailer, bags all packed and will be leaving for Clayton in a few minutes.:cheers: :cheers: :cheers:
Congrats....
Way to go Don!!!!
So, why are you still on-line?:evil:
