O.T. - 3/4 ton J-10 input needed
1x1_Speed_Craig
Simplify...
Greeneville
TN
I have a chance to pick up an '80 3/4-ton J-10 truck for $400. It has the Dana 44 front (driver-drop) and Dana 60 FF rear axle (3.73 gearing), and the frame is solid with the exception of the rear main eye hangers, which I'd need to reconstruct somewhat. The 360 will be pulled before I get it, but it has the T-18 trans and NP-208(?) t-case.
My thought is that I could switch plans and use the HD J-10 setup for the basis of my CJ-10 project (rather than the YJ frame/axles). It would give me a much longer flatbed setup, as well.
What do y'all think?
Craig
Picture this, only longer...
forum
J10 wheelbase is a litle too long (never thought I would hear myself say that) @ 116 or 131" WB depending on bed length, for some trails. Also, I think the frame has a lot of kickup at the axles, so the middle of the frame would be pretty low. Thos two things combined would give you fits on breakover angle. (I loved my old M715, but hated the breakover, even on 38.5X11.00 Boggers)
You will also need to bob the frame behind the rear springs, and I really don't like the location of the fuel tank on the J series.
I say go for it. I would look more like the one Matt's friend did in this thread. I always thought that was cool.
Started with a 85 CJ10a tug, and removed the cab. Placed the cab on a 86 Grand Wagoneer frame and running gear. AMC 360 V8, automatic 727/NP208, D44 F & R. Truck bed was fabricated out of a very nice 1/2 ton military trailer and mounted to the frame.
Truly a unique vehicle and real head turner. And the best part is its a CJ without "driving" like a CJ. It rides like a grand wagoneer. Currently driven every day.
https://www.cj-8.com/forum/showthread.php?t=5845&highlight=cj10
and here
https://www.cj-8.com/forum/showthread.php?t=6214&highlight=cj10
Truck
I like the idea of a Waggy/FSJ Cherokee swap better, as you end up with axles that are pretty similar in strength, while still being able to easily use 15 wheels, and not having that D60 hanging down. (The D60 in the J10 is only 30 spline)
You also would have only a 109" WB. :rolleyes:
For the sake of not having to link to the other posts that Truck mentioned, I added a pic of the truck he's referring to below. Matt Donaghy e-mailed me the link again today, which is what got me thinking about this route.
As I mentioned, the longer frame would give me more flexibility bed-wise. I might consider building a Brute-like bed with this setup, whereas it wouldn't be practical with the shorter YJ frame.
Other bonuses would be less money invested than with the YJ setup, and stronger axles (which I'm not sure I'll need or not, but it's nice to know you got 'em :D ). It would also make a REALLY stout setup for a recovery vehicle. :cool: Regarding the work for adapting the tub to the frame, I'm guessing it'll be about a wash. The only thing I'm not sure about is motor mounts for the '01 XJ 4.0.
Cooter - Thanks for the insight. I didn't realize they had different bed lengths. I'll have to figure out if this is a short or long bed. The fuel tank could be relocated (using the XJ tank/pump that I have, or a fuel cell). How does the breakover angle weigh in against the heavier axles, extra bed length, and price in your opinion?
I won't need to use the T-18 trans or t-case, and could recoup some $$$ by selling it. I'll be using the '01 XJ AW-4/NP-231.
Craig
forum
BTW...the money is a definite consideration. We're looking at buying some property to build (or buy a house if we find just the right one. The savings with the J-10 setup would be considerable if I sold off the YJ parts.
BTW, if I ever start talkin' crazy and decide to get rid of the CJ-10a tub, you'll be the first to know Cooter. :)
Craig
It all depends on what you are doing with it.
If you are doing trail rides in the Manistee, I would say go for it.
If you are planning on climbing rock ledges, or rockcrawling I would say "No Beuno" (The '715 climbed fantastic, but once I got to the breakover at the top..)
Beadlocks are more expensive for the 16s and 16.5, unless you go with the Hummmer BL, which might no be such a bad idea, after all.
Ya know, as I am typing this (in between editing out some of my worst spellign errors :D), I'm staring to warm up to the idea- the hummer B/Ls will narrow your track a little, which is sorely needed as the J10 has wider axles than the regular late model "Waggy Axles"
It might not be too bad, as long as you keep it in it's intended element, and if it isn't the 127" WB. (You could always shorten the frame, it would be your next logical step in your "Mods That One Doesn't See Every Day"
I keep fighting the urge to buy the '715 off of MJ, and there is another in the UP on Pirate, as well- thanks for putting them back in my head. :mad:
Thanks Cooter. Are the Hummer BLs 8-lug then? I have never researched them, as I never had more than 6-lug wheels (on my '76 Chief). There's a guy here in Michigan (you probably know who) who has ~80+ Hummer wheels/tires that they got through a bulk military purchase. Hmmmmmm.
The other option I could go transmission-wise is to use the J-10s T-18/t-case and sell my AW-4/NP-231 (48K miles). I just don't know as much about the condition of the J-10 stuff, and what would be required to mate it to the '01 4.0.
Craig
Is Matt still around? I haven't seen him on MJ in months. (One of my MoPar friends from down the street picked up some 1/2 doors from him while he was heading down to pick up those B/Ls- very small world)
Hummer B/Ls are 8 lug- I haven't messed with them much (I'm not running anything 8 lug but Nuthugger on GLJT has a set he is using on his CJ5 project to narrow it some), so I don't really know a lot on them besides the fact that there were radial and bias ply versions- P4x4 has a ton of info on them, though (Remember to use the search there :D )
You would need a provision for the CPS, and speed sensor- I think that the speed sensor will plug right into the speedometer housing. The CPS can be swapped to the front with a fairly expensive kit (Includes a harmonic balancer machined into a tone ring), or you can find an aftermarket bellhousing setup for the CPS (expensive again, but there may be someting that will swap and I just haven't heard of it), or modify you existing bellhousing (tricky, but can be done- there even may be a kit) the bellhousing bolt patterns were the same between the 6 and 8 cyl AMC motors. Then it gets a little tricky- you need a 4.0 specific flywheel for the CPS if you keep it mounted on the bellhousing- actually, I guess not so tricky, as it should match up to the T18. You also have to make sure you have a pilot bearing in the back of the crank for your input shaft on the T18.
There may be a different length speedo gear- I think I remember that there were long and short gears over the years, but I can't remember when they changed over (some where in the YJ years, IIRC), or how to swap them.
If you have an '01, then are you running an OBDII setup? There are issues with aftercat O2 sensors, and some other issues that you would run into with either frame/tranny setup.
I agree with cooter, I love my m725, but man the length sucks if you hit a dead end trail. It takes like a 7 point turn-around. Make sure its the short wheel base version or cut it down. Not to highjack the thread, but cooter, have you been to the m715zone.com site?
Yeah, I haven't seen him lately. I'm surprised, as he was planning on making the Jeep parting business a more full-time gig. I'll be sharing an inventory software app that I'm writing with him when I'm done.
I'll be sure to search on Pirate. I think I may have seen that suggested a time or two. ;)
I haven't investigated the issues, but I do have all vehicle wiring and the exhaust all-the-way-back from the donor vehicle. That's why I planned on sticking with the factory XJ setup all-around...less headaches.
Anyone else want to share your opionions (I know you got 'em :D )
Thanks again,
Craig
IIRC, Matt's friends rig was built on a Waggy frame though, not a J-10...
Just making sure that we were talking apples to apples in case you were liking that length/wheelbase.
I was kinda thinking that if you were going through the trouble to build something like that for dedicated trail riding that you really wanted more wheelbase, but I certainly know about using what you have, so I didn't mention it.
If you're open to other paths, I'd really look into something with more length and maybe getting this thing and shortening it up would be a good way to go.
Is the bed separate in the J-10? If so, you could section the frame and bed the same way and have yourself a usable bed (even if you chopped the sides to make your flatbed). I could see a cool bed with just 8" or so sides and lots of tiedowns, a semi-flatbed. imagine a shovel and hi-lift mounted along the stubby sides... that's kinda what I picture.
Anyhow, you asked for other thoughts... ;)
I'm 99.9% certain it's the longbed version. The frame would probably have to be shortened, or I could possibly find a Waggy frame locally, and use the J-10's axles. I have seen some pretty nice Waggies go for next to nothing around here.
Well, the YJ frame will actually have a ~104-105" wheelbase (Scrambler length+) with the Waggy front springs all-around, and the BTF rear bumper setup (moves rear axle back 6.5"). How much longer do you want? Now you're sounding like my old girlfriend. ;) :D
A guy that goes by KYJ10 on ifsja.org has done some wild stuff with his J-10...most recently, tubing out the back and going with a 4-link setup. That's a whole different box 'o worms, though.
The bed is separate, but not in great shape. It may be partially usable with the stubby sides like you mentioned.
I think that, given the fact that I have 99% of the parts I need for the project already, it wouldn't make sense for me to go the J-10 route. Still, the purchase is nagging me...$400 for the frame, Dana 44/Dana 60 axles, T-18 trans & NP-208 t-case is SCREAMING "future project...future project...". Still debating as to whether I'm going to pick it up anyway. :confused:
Craig
j20
Just to clarify, this is a J20, not a J10. This is per the rear 60 and T18 (both only offered in a J20 after 1980).
I say go for it. One thing to keep in mind with this set up is that the drivetrain is going to be very long. There are 2 large spacers that are about 7" each, one at the bell housing the other at the tcase. So it means your drivetrain from bell housing to to rear output yoke is about 4 feet long. On the wagoneer frame, it means the stock "coffin" gax tank won't fit (ask me how I know lol). So it's defintely a deal where you need to use a FSJ frame with a long wheelbase because even with a scrambler wheelbase your looking at a rear driveshaft that's only a couple feet long. The other thing to note is that the T18 / NP208 is a rare bird, there are very few manual J20s after 80'. The NP208 is actually 31 spline and not 23 like all the other FSJ NP208s (behind the 727s and T176s). It's got a 2.62 low range which is good but it is an aluminum, chain driven case. KYJ10 runs this set up so it's not necessarily a bad thing, just sometihng to keep in mind.
I found this is little late and probably missed it but what's wrong with the 360? Why run a 4.0?
Anyway, this is turning into a very cool project, especially if you get the J20 set up.
Thanks Panther. I decided to stick with the YJ frame I already had for my CJ-10a project (I already have nearly everything needed to complete it).
I don't really have the space for the J-20 (if that's what it is), but still the potential purchase is plagueing my thoughts. I'd really like to do a cool future project with it. The current owner is a friend of mine, and is on this forum, as well. Hopefully, he still has it if/when I decide to get it. :confused:
He's planning on keeping the 360, BTW.
Craig
Well, I ended up picking up this rolling chassis, including the Dana 44/Dana 60 axles, T-18 & NP-208 (everything but the motor, basically) for $300. I'm not sure what I'm going to do with it yet, but I definitely have to find a place to store it in the meantime. Maybe it'll get an aluminum Scrambler tub someday. :D
Thanks for your input, guys. Much appreciated (as usual). :)
Craig
