O.T. - YJ/XJ/CJ-10a hybrid project - PICS
1x1_Speed_Craig
Simplify...
Greeneville
TN
Well, after a few hard days of work, I transformed a BIG pile-'o-parts into a semi-assembled, mocked-up vehicle (we're moving in a few weeks and I didn't want to move all the parts individually).
More details on the plans for this project HERE.
It's nice to see all the parts I have been collecting for the past 6-8 months or so come together somewhat. :)
Craig
forum
forum
That tub looks so cool on there like that. You better build out the wooden flatbed for me! (Always liked that look).
Are you going to have to move/fab new body mounts for that tub I assume? It doesn't happen to line up with the existing ones, right?
Fire that thing up and let's get some wheelin pics already! :D
That looks pretty cool Craig.
Are you going to add a full cae that will taper down to the rear?
Looking forward to a good buildup story on that one.
Carl
That thing looks so close to mine they could be brothers or sisters...or whatever...you get the point. I haven't had my half hardtop off but I guess it would look just like that. Except my Wrangler parts don't include square headlights :eek: - mine must the be the good brother with the round head lights :D
EDIT >> just realized shorter frame and non-Scrambler...I guess our Jeeps are distant cousins then...the kind you don't see for like 3 years and you have to be re-introduced when you "meet" them again. Oh well :p
Kewl... me likey. Can't wait to see it finished.
What are you going to do w/ the rear? Wood flatbed like BW mentioned, or???
I have a hand-sketched version of what it'll look like when it's done, but as much of a computer geek as I am, I don't have access to Illustrator (or other illustration applications). I'll see if I can get a scan of the sketch and post it in the near future.
The flatbed will probably be steel. I'm thinking of using black diamond tread (no shiny stuff here)...who knows, though. I hadn't thought of building a wood bed, and I do have quite a bit of woodworking experience (Pic 1, Pic 2). I'll have to give that some thought.
A full cage will be built using a tubing from a few OEM Jeep rollbars, and supplemental tubing. The front of the cage will actually bolt to some "PSC Rocker Knocker"-like 3/16" rocker guards that will wrap around the back of the tub. It's a little hard to explain, but it looks like a solid design, and I got the "nod of approval" from a resident cage builder who's on this board. :D (I was pleased, being a newbie cage designer and all. ;) )
I just got the front axle hung last night, so it's officially a rolling chassis now. This will make it easier to move to our new house in a few weeks (UGH...moving...).
Craig
That looks great. But.... IT'S TOO SHORT!!! :D Just kidding. it does look very nice.
Thanks Dan. Size isn't everything, though...at least that's what I have always told myself. ;)
Actually, after the 9" wheelbase stretch is done, it should be almost the same as a Scrambler. I already gained 2" on each end by using Waggy (FSJ) springs w/offset pin front & rear. I'll also be moving the rear main eye hangers back 5". I'll be using CJ shackle hangers that will mount under the rear bumper. Without moving the rear main eye hangers, the tires would rub on the back of the tub.
I could gain another 1" by using the offset holes on the M.O.R.E. spring perches, but I'll probably just use the center hole after gaining so much wheelbase from the other methods.
Craig
