oak ridge oops, or whats wrong with my jeep now
Jeremy
Scrambler Fanatic
Carlisle
PA
This is a lesson, Always always inspect a field repair once home and do not assumn that its ok especially one done in the middle of the night along the trail or camp.
I Got my replacement hubs to replace the destroyed one down at oak ridge yesterday just as I was leaving for work. On my way home when I touched the brakes at a stop sign the jeep pulled hard to the driverside. I gingerly drove home and got up earlly to investigate more in the daylight. ( I work night shift) Once I pulled the wheel off the problem became apparent. The brake rotor was ground away to nothing on one side clear down to the cooling ribs it then broke off behind the hub spindle. What caused it, never seen it, never heard off a rotor doing this? Looking closer I just had to sit back and laugh at my own (our, those of us on the late night oak ridge repair crew) foolishness. I take the blame for this cause I should have been double checking things but some dingbat (that would be me) put the brake pad on upsidedown and backwards in effect the abrasive to the outside and the steel backing plate against the rotor. Weird that I did not notice any effects to my braking or steering until the rotor failed as I was coming in to that stop sign.
My jeep is once again up on jackstands, I got all the parts I need except the rotors, they will come tomorrow. In the mean time I need to make another jeep to run or borrow mom's car again.
Its 02:00 and I still feel pretty dumb
Just finished redoing the brakes and replacing a rotor.
