Officially Screwed for Nationals
Truck
Manassas
Va
Well, I'm officially screwed. My tow rig is hosed. Some of you know I was changing a cracked flexplate on my tow rig. Turned out not to be cracked but the bolts had come loose and sheared 3 of 6 bolts on the torque converter. Okay, still fixable. New flexplate, retap the TC, new bolts. It was also leaking oil bad, so I figure it had torn up the rear main seal. A pain but drop the oil pan, new rear main seal, new oil pan gasket and I'm good to go right....WRONG :evil:
So I drop the tranny and get the flex plate and TC out. Retap the TC. Have all my parts. I drop the oil pan, this weekend, but it was late so I go to finish today after work. I pull the oil pump and about to pull the bearing cap when I look over at oil filter area and my heart just sinks...:banghead: I find this..
attachment.php
attachment.php
attachment.php
attachment.php
So the only way to fix is replace the engine or the block. Neither one do I have time or money to do, especially before Nationals :angry: . This is the only means I had to tow my junk to TN. So I guess I will not be traveling with my Scrambler. :(
Anybody have a 6.2 or 6.5 diesel laying around??
Truck
I do but I'm on the other side of the world. It came from a H1 Hummer that we put a 500ci stroker motor in...
Just put JB weld to the test! :D
Or better yet, go for the ultimate adventure and drive the Scrambler! :eek:
I would talk to a good welder, one that knows about specialty rods. I have a friend that could weld that up in about 2-6 hours then it would be a simple case of grinding/machining the surface back down for the seal to seat. Due to space limitation, you may have to pull the engine, but since most of the drivetrain is already out and you would have to do it any way, nothing lost.
Bear Claw said:
How the hell did you do that!?!?!?:eek: :eek:
Well, it looks like one of the sheared off bolt heads hit it. If you notice all the shredded steel up on the block, that is where I found a bolt head.
Found somebody who could lone me a double gooseneck trailer, any of you Virginian's going down have gooseneck hitch?
Truck
JB Weld
Man if you have that other piece you can JB weld it. I have seen blocks fixed with it why not that. You just have to take your time and v-notch it / fill it grind it a little in another v-notch and do it again until it is filled up. Takes time but i think it is a shot.
Very sorry to see that, Truck...
maybe get it towed to a certified welder and have them fix it up for you....
